F355 gearbox filter screen | FerrariChat
Discussion in '348/355' started by group77racing, Dec 18, 2013.
  1. group77racing
    group77racing Formula Junior
    Sep 5, 2006
    453
    Often Imitated
    Never Duplicated
    Does the 355 6 speed gearbox have the "hidden" filter screen as the 348 5 speed box? the service manual mentions one, a "screen" I believe, but does not show its location.
  2. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Not sure what screen your referring to but the ds cover on the GB where the oil line runs has a small scree in there.
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
  4. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,185
    So. CA & NV
    Peter
    Should I have changed that last time I changed the fluid? if so, is it an easy process?
  5. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    The only thing that screen does is keep big bits from getting into the oil pump. That and you have to remove the side cover to get to it, which is almost impossible to do with the gearbox in the car. The studs are really long and the side cover will hit the subframe preventing it from coming off. So no, it's not an easy process.
