Hi, I have a white area of light on the speedo, when everything else is very green. On inspection and removal of the little light at the back of the speedo, it has lost its small green cover that gives the light its green effect. I checked the other bulbs and they all have their little green condom in place! Where can i get on of these small green light covers or is there another solution to get the green light effect back? many thanks Mark
A professional photography supply house should be able to closely match the "gel" that turns the light green, and you can rig it to cover your bulb somehow. Very inexpensive fix if easily doable. Or call Ricambi, they might help with a more legit solution.
Hi 275 GTB! I had this exact same problem! Easy fix. Just contact any instrument repairer. These green sleeves are obtainable in different sizes and are only a few cents ea.
