F355 GTB power window alignment | FerrariChat
Discussion in '348/355' started by salbrech, Apr 20, 2014.
  1. salbrech
    salbrech Karting
    Dec 20, 2013
    107
    Good evening everbody,
    I am new in this forum, reason for that is that a week ago I bought my first to me Ferrari and already have quite some work with it (bought without warrenty / living in Switzerland), therefore appreciating some assistance from you guys:
    The problem I am currently working on is my LH power window, which is not fully closing. When reaching its top end position, the glass is sitting around 1/2 inch to much "to the front", with the effect that its not complety sealing (so not water proof anymore and wind noise while driving annoying). This misalignment can clearly be seen, especially when comparing with the RH window (unfortunatly could not make pictures to explain better).
    Therefore I assume I need some kind of "re-allignment" of the window mechanism. However, was not sure about how to dismantle the parts of the doors to get acess to it. I was able to remove the long inner trim (the one with the pocket and the metal clip), the door handle and the door release lever. Then I was not sure anymore which part needs to go off next and how.
    Can somebody give me advice how to re-align the window mechanics and how to get acess to the relevant parts.
    Many thanks and greetings from Switzerland
