F355 Head Scratcher | Page 3 | FerrariChat
F355 Head Scratcher
Discussion in '348/355' started by yelcab, Aug 6, 2020.
  1. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Its a god test though test drive with O2 unplugged
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    I have only seen the problem when the car is hot and after sometime driving.
  3. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,033
    NE FL
    Ken
    Like 5 minutes or like 30?
    I image it takes 4-10 minutes to go from open loop to closed loop.
    If it's a longer period, that points to something thats prone to heat soak. Electrical components.
    Anything mechanical would present it self all the time imo.
  4. Beetle
    Beetle Formula Junior
    Apr 10, 2013
    776
    Fuel tank vent
  5. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    breaking up at rpm yeah crank sensor
    Fuel trims, crank sensor also if thats the RPM issue
    TB's absolutely suck after 25 years. I rebuilt 2 sets and car felt like new. With play and air gaps was hard to hold a metered flow. Smokey test those suckers while your playing. I have the 12 chanell mercury tubes I use to tune them if you need them
    Qavion likes this.
  6. yelcab
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    #56 yelcab, Aug 14, 2020
    SoCal1 Tim. I did a smoke test on the intake (and exhaust) and no such leaks were found. Tight as a drum on the intake side. Slight leak on the exhaust side.
    Big update today.
    1) we are taking the engine out because it has been more than 5 years since the major service (which I did on this car) and it is showing major signs of due time again.
    a) oil leaks in several seals and gasket places
    b) broken cam shaft position sensor
    c) gearbox oil leak at the right side cover
    d) cappuccino color gear oil meaning the heat exchanger is done for
    e) water pump coolant leaks
    So instead of peace meal approach, it is coming out this weekend (Eff the 95F weather)
    I'll keep a running list of things I found and update this thread when I close the engine back up.
    Qavion likes this.
  7. tatry68
    tatry68 Karting
    Oct 27, 2013
    120
    Chicago Suburbs
    Stan
    I just wanna say that I appreciate this write up cause it is a teaching tool for all of us that do our own work on our cars. I wish I could help, but I have no new ideas as to whats going on with your problem child. I can't wait to hear what fixes it. Best of luck Mitch. You are a great asset to F Chat members.
  8. yelcab
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    Before the engine is out, I wanted to add more diagnostic data so I made up this to-do list before engine out.
    1. Check combustion temperature for each cylinder at the exhaust
    2. Check ground points at the head
    3. Check crank sensor operations
    4. Check cam sensor operations
    5. Check throttle position sensor operation
    6. Check MAF operation and numbers
    1) it turns out I am unable to do this because my Laser thermometer only goes up to 500F and it won't be good enough for this test. I need to get a new one.
    2) Ground point checked out for this engine at rear of Bank 1
    3) Crank sensor visually inspected OK.
    4) Cam phase sensor, broken connector. See picture.
    5) Throttle position sensor has one number out of six that is out of spec. Pin 1-3 resistance at Wide Open Throttle is 1.2 kohms, instead of 1.0Kohms maximum. This needs replacement
    6) MAF air flow sensor read maximum at 3.5 volts, and needs to be higher than 4V see picture.
    I have always believed this car has multiple issues .... and so far it has not disappointed.
    This is added to the previously found issues:
    Loose number 6 injector clip.
    Bad one-way check valve on secondary air pump circuit, bank 1
    Leaky exhaust gasket, bank 1 right before Pre-cat O2 sensor
    Disintegrating rubber bits inside fuel tank
  9. fatbillybob
    Aug 10, 2002
    29,379
    socal
    what a mess! I thought you verified good cam n crank sensors?
  10. yelcab
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    I verified the crank sensor to be physically in tact, wires not messed up, and nothing is cracked. But we will change it anyway since it is 25 years old.
    I did not verify the cam sensor until just recently. The wires are intact but the connector is cracked badly and it can't be good.
    The MAF sensor thing needed a Digital Oscilloscope set up properly to capture the one time event of snap throttle closure which... happened today.
    And I am still scratching my head as to why Bank 2 is running rich and Bank 1 is running Lean as reflected by the LTFT. Also the rear O2 sensor is bouncing all over and that is just not right. I might put it back together with a set of borrowed original Cat converters to see if that makes a difference.
    Oh and added to the list:
    Broken Cam Phase Sensor
    Out of spec MAF sensor
    Cracked idle T-connector hose
    Cracked hose at secondary air pump connection to Bank 2
  11. Qavion
    Qavion F1 World Champ
    14,625
    Ian Riddell
    The resistance goes down with throttle application. 1.2 kohms doesn't sound like it's out of spec if 1Kohms is a maximum.
  12. yelcab
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    It's out of spec, whether it matters or not is a different thing.
  13. Qavion
    14,625
    Ian Riddell
    Just checked the manual and I see what you mean. I thought you meant that 1Kohms was the most extreme value allowed (from the no throttle value).
    Maybe I should change mine. It's even further out of tolerance than yours. Or could it be a cable/throttle body adjustment problem? My no and full throttle values are shifted in the same direction. What was your no throttle value?
    Folks, for reference, full throttle = 850 ohms +/-18%, no throttle is 2000ohms +/-20%
    On my Lotus, you could adjust the position of the sensor slightly. I recall someone trying this on a F355 by widening the holes on the mounts.
  14. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    As far as the TPS yes you can tweak it as such I did mine this way as well, 348 yes but pretty sure it the same on 355's.
    https://www.ferrarichat.com/forum/threads/348-throttle-position-sensor-adjustment.453969/
    Pretty much, a combination of issues as suspected. You'll get it for sure resolved. Problem is these cars tend to compile things, many things that make toxic pairs that is hard to diagnose as one item. Abbreviated list below that I did to avoid the situation you find your self in, you may want to consider some or all of these. Best of luck!
    • crank sensors
    • phase sensor
    • MAF
    • TPS
    • FPR
    • Fuel pumps
    • Injectors
    • Coils
    • Ignition modules
    • Every Check valve in the engine bay
    • New vacuum lines and fittings
    • Water temp sensors
    • Oil Pressure sender
    • O2 sensors
    • Thermocouples
    • Every light bulb in the entire car (dash included)
    • Plug wires
    • Plugs
    • All new relays
    • All new fuses
    • Thermostat
    • Fan temp switch
    • Oil temp sensor
    • Oil temp switch
    • New radiator fans
    • New ground wires and add 2-3 new ones
  15. yelcab
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    Eric,
    I am approaching half that list already. Likely to include all the ignition parts. By the way, what does replacing the Oil Pressure sender have to do with ignition, or your problem? This car does have a high pressure reading.
  16. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Absolutely nothing. While the patient is open and all that. It costs almost nothing to replace, your there, and avoids another fire drill later. My car has 0 problems and I mean 0. I'd hop in and drive it cross country and not give it another thought.
  17. fatbillybob
    Aug 10, 2002
    29,379
    socal
    Crazy mitchel that all that stuff is broken since last 5yr service. My 550's suffer great underhood temps and when the 5yr comes it's like gee why am I messing with this perfect car? Anyway Bosch makes bad sesnors. I have had so many cam sensors just crack/disintegrate with the heat and fall apart in my had when removed that I just replaced them every 5 years. I use the kia 348 crank sensors and adapted it to the 550. They are so cheap I bought a dozen about 15 years ago. What a mistake! The bosch sensors fail all the time. To this day I have never had a kia crank sensor fail. I still have about 8 new ones left.
  18. yelcab
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    He's got after market unshielded headers on this car and all that heat is dumped right into the engine bay... cooking everything in the way. Remind me to check the engine mounts.
  19. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Next time engine is out I'd yank the headers then swain coat them inside and out, maybe wrap them too for looks.
  20. fatbillybob
    Aug 10, 2002
    29,379
    socal
    Sounds like you need to wrap those headers.
  21. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
  22. yelcab
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    So, the engine came out this weekend. The more I see, the less I want to see.
    Something has caked the entire front of the engine. Imagine an animal died and left its carcass behind.
    Water pump toasted.
    Idle valve T-hose cracked.
    Both knock sensors broken in pieces (this might explain a lot)
    Cam position sensor cracked.
    Power steering hoses (all) are leaking
    All oil hoses are leaking.
    Cappuccino color gear oil.
    So the list just kept growing.
    Qavion likes this.
  23. yelcab
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    And now the list got a bit longer:
    Ignition related:
    Cracked TDC speed sensor (new today)
    Cracked, broken knock sensors (yesterday)
    Service related:
    Water pump toast
    Leaky oil lines (3 main ones)
    Leaky Power Steering lines (hi pressure and low pressure)
    Leaky heat exchanger
    Leaky gearbox side cover
  24. GTUnit
    GTUnit Karting
    May 25, 2014
    143
    Socal
    Jack
    I was going to say check or replace both water temperature sensors. They are cheap. I've seen a no CEL, garbage running, condition on a motor before and that was the problem.
    Qavion and Beetle like this.
  25. yelcab
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
