F355...How many cats..?? | FerrariChat
Discussion in '348/355' started by PKF355, Oct 21, 2009.
  1. PKF355
    PKF355 Formula Junior
    Nov 12, 2003
    701
    sOCal
    Patrick
    This may be a dumb question but I can't seem to figure out...
    How many catalytic converters do F355's have? Two or Four?
    All this time I thought there were only two. But recently I've heard people saying there are two primary AND two secondary cats!!??
    If those secondary cats are the ones that people most referred to when they de-cat (as in putting on a straight pipe) or replacing them with aftermarket units such as hyperflows, then where are the primary cats? Are they located by headers (exhaust manifolds) or by Y-pipe??
    Can someone knows this stuff for sure please educate me....Thanks much.
  2. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Four total .......... two primary cats ....... two secondary cats ...... secondary cats are utilized when the bypass valve opens, at that point all four cats are in play. :)
  3. Vegas-Guy
    Vegas-Guy Formula 3
    Nov 25, 2007
    1,828
    Austin, TX
    Reg
    #3 Vegas-Guy, Oct 21, 2009
    My '95 only has two...:) but it's a 2.7 and not a 5.2
  4. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    So no secondary cats on the y-pipe :confused:?? That would explain some of the extra 5 HP rating ..... :eek:
  5. bst1
    bst1 Formula 3
    Aug 13, 2005
    1,055
    MARYLAND
    BARRY T
    #5 bst1, Oct 21, 2009
    Actually , I believe there are cats in the Y pipes in 1995. The increased horses are due to the less restrictive airflow and the OBD1.
  6. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    #6 cf355, Oct 21, 2009
    This is correct, the Y-pipe incorporates 2 metallic cats for the bypass, just like the later 5.2 cars.
  7. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,690
    Yes the y-pipe has ttwo cats in it.
    No its not just like the 5.2 pipes.
  8. 355dreamer
    355dreamer F1 World Champ
    Apr 3, 2006
    10,476
    DC Metro
    L.C.
    Mine has zero... :D
  9. PAP 348
    Dec 10, 2005
    100,213
    Mount Isa, Australia
    Pap
    #9 PAP 348, Oct 21, 2009
  10. Vegas-Guy
    Vegas-Guy Formula 3
    Nov 25, 2007
    1,828
    Austin, TX
    Reg
    There are cat in the Y pipe? Hmmm are they just as bad as the other cats?
  11. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,822
    Hamilton, NewZealand
    James
    I LOL!!!
    Man, your a clown! :D
    (Thanks though, I can do with the laugh....)
  12. PKF355
    Nov 12, 2003
    701
    sOCal
    Patrick
    Oh, I get it. there are 4 cats and one p*ssy. :D
    Seriously, thanks guys for all your info/input.
  13. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,424
    CT
    Jay
    There are, one for each side. During my major I pulled the Y and cut off the heat shields. Found signs of heat build up just in front of each cat...so I de-catted and ceramic coated. There's no O2 sensor after the bypass so OBDII has no clue...
    I posted pics in my 355F1 engine out thread
  14. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    That is what I thought ...... they all have 4 cats from the factory, except the 2.7 has a slightly different shaped y-pipe and different headers to meet up with that different y-pipe.
  15. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    +1 .......... that missing 5 crank HP is easily regained with 'hi-flow air filter tops' for the 5.2 ......actually at least 5 'wheel' HP .............. ;)
  16. 355dreamer
    Apr 3, 2006
    10,476
    DC Metro
    L.C.
    Oh come on now Goth... That is some shameless self promotion. There's no way a new airbox cover can overcome the defecits of the 5.2 v the 2.7
    :):D
  17. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    I wish it weren't true ...................... but it is ................... :eek:
  18. PAP 348
    Dec 10, 2005
    100,213
    Pap
    :eek::eek:
  19. JSBMD
    JSBMD Formula Junior
    Mar 17, 2007
    449
    The OC
    The Y-pipe cats are the bulges on either leg of the (upside down) Y. Looks like a snake swallowing a cat to me.
    I also wonder why we don't see as many problems with the secondary cats as we do with the primary cats. My guess is that due to the bypass valve being closed most of the time the cats don't heat up as much as the primaries.
  20. Mitch Alsup
    Nov 4, 2003
    9,690
    A: exhaust does not flow across them most of the time (car in standard trim)
    B: they are not in the path where the ECU cares
    C: If they did go out, who would know--certainly the sniff test does not use this path
    I do happen to know that they choose metalic converters, here, so that the converter would heat up fast (fraction of a second at full throttle).
