F355 humming sound from rear with tender hooked up | FerrariChat
Discussion in 'Technical Q&A' started by Lee Marks, Jun 2, 2021.
  1. Lee Marks
    Lee Marks Rookie
    Aug 22, 2020
    37
    Lee F Marks
    #1 Lee Marks, Jun 2, 2021
    So my F355 is doing something very strange. I've driven it a lot lately and it has performed very well, no issues.
    Things get a little weird when it’s in the garage. I’m hearing a quiet humming sound that lasts for maybe 5-10 seconds then stops. This keeps repeating randomly days after it’s been driven. I’m hooked up to a Battery Tender Jr.
    Anyone have any ideas?
    I thought maybe a bad diode in the alternator but there is no heat to the touch.
    The car has a manual trans.
    Thanks in advance!
    Lee
  2. Qavion
    Qavion F1 World Champ
    14,527
    Ian Riddell
    I guess 5~10 seconds doesn't give you enough time to pinpoint the location of the humming. Have you hooked up the tender to the engine compartment terminals? Could it be the tender itself making the noises?
  3. Lee Marks
    Lee Marks Rookie
    Aug 22, 2020
    37
    Lee F Marks
    The tender is outside of the engine compartment and nowhere near source of noise.
    Seems to be coming from firewall area behind the drivers seat.
  4. WATSON
    23,926
    WI
  5. Qavion
    14,527
    Ian Riddell
    Why would the idle air controller be humming with the engine off?
    On the hot side? On the cold side, there is the alarm ECU? Is the car a 2.7 or 5.2?
    Do you have any aftermarket stuff fitted? Exhaust Bypass controller wired up to the battery? Aftermarket stereo system picking up interference?
  6. Lee Marks
    Lee Marks Rookie
    Aug 22, 2020
    37
    Lee F Marks
    So would that valve be powered without tender attached?
    I have Fabspeed headers and an exhaust fitted.
    Qavion likes this.
  7. WATSON
    23,926
    WI
    No idea on that. But that buzz is most likely from that valve as I had the same thing after shutting the engine off. It lasted just long enough for me to run to the back and find it. I actually replaced the valve 10 years ago thinking it was broken....same thing happened with a new one.
    Is voltage getting to it when the maintainer energizes to charge the battery and it buzzes briefly?
    Do you have the battery disconnect off? I always do that so no voltage walks back to the electronics.
    Ian, any idea if there is a delay anywhere in the electronics from the time you switch the key off until all voltage is dropped?
  8. Qavion
    14,527
    Ian Riddell
    IAC power comes from a relay which is energised by the respective Motronics ECU (if there are two ECUs). The 2.7 Motronic car has two idle air controllers, the 5.2 Motronic car has one controller. Normally you'd need the ignition on before the ECU will energise this relay. However...
    The behaviour you observed would suggest that the ECU has some kind of power circuit with big capacitors and takes a while to remove power from the relay. I guess you could prove it was an IAC by simply pulling the plug/s, but why would the relay or ECU power up after two or three days? The ECU has battery power on it at all times, but you still need to turn the key to get the ECU to activate the relay. Hope it's not a faulty ECU.
    Curiouser and curiouser...
  9. Lee Marks
    Lee Marks Rookie
    Aug 22, 2020
    37
    Lee F Marks
    IAC?
    So I drive car at least once a week and don’t disconnect the battery. Just plug in tender and cover.
    Am I storing it wrong, should batt be disconnected when car is sitting.
  10. Qavion
    14,527
    Ian Riddell
    Idle Air Controller.
    No. Using the disconnect knob, you may prevent the battery charging (especially if you have the tender hooked up to the terminals in the engine bay.
    Or another possibility. The battery power going to the ECU allows the ECU to power down it's relay control circuits over a certain time period. You wouldn't want permanent power on the control circuits as this would drain the battery.
  11. Steve Magnusson
    26,932
    The valves in the fuel evaporation control system can also vibrate/hum/wheeze for a while. Still could be something else as the others indicated (I don't know 355 well), but you can easily rule this in, or out, by just unscrewing the gas cap to quickly vent out the residual pressure in the gas tank (and/or leave the gas cap loose so pressure never builds "days after it's been driven"). Your remark -- "This keeps repeating randomly days after it’s been driven" -- seems strange for an electrical item. Just a thought...
    Challenge and Qavion like this.
  12. Lee Marks
    Lee Marks Rookie
    Aug 22, 2020
    37
    Lee F Marks
    Thanks for all your replies!
    Still a bit of a mystery but now have some good info!
    Thanks again!
    Qavion likes this.
  13. PaulK
    PaulK F1 Rookie
    4,801
    Michigan
    Paul
    The two-way valve (the drivers side of the car) sounds like a kazoo or a buzzing noise:
    (the red "thing")
