F355 Immobiliser issue | FerrariChat
Discussion in '348/355' started by martinperry, Feb 21, 2017.
  1. martinperry
    martinperry Karting
    Jun 4, 2008
    127
    Sawbridgeworth, UK
    Martin Perry
    #1 martinperry, Feb 21, 2017
    Hi All
    1995 Euro Spec (LHD) F355 GTS 2.7 motronic.
    Car has been stood for a couple of months, and has managed to flatten its battery.
    Connecting up a jump pack, immobiliser light comes to life, constant flashing
    However, it then refuses to go out when I press either button on the key fob, and, obviously, the car then refuses to start (cranks fine)
    The fob doesnt operate the locks either. I have 2 fobs, both with brand new batteries - same lack of response to both.
    Ive attached a picture of the fob and key setup (cant find one like this anywhere on the net!!)
    Any suggestions?? Where is the bloody immobiliser, how to bypass etc
    Many thanks
  2. buddyg
    buddyg F1 Veteran
    6,376
    Naples, FL
    Buddy
    95's in the US did not have immobilizers? Is this different for the UK?
  3. martinperry
    martinperry Karting
    Jun 4, 2008
    127
    Sawbridgeworth, UK
    Martin Perry
    Im Guessing so!!
    No mention in the handbook, and no alarm supplement, but this looks like an "official" keyfob (car was originally French, supplied by Ch Pozzi)
  4. WATSON
    23,866
    WI
    Well, no idea on UK spec cars, but my understanding was 1995 were sans the immobilizer (wish my 98 was too).
    My guess is an aftermarket, dealer installed immobilser complete with fancy yellow sticker with horsey on it.
    Did you put a new battery in the fob?...ah yes, I see now you did that. You sure they are in there right? :) I kid! (kinda)
  5. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    I'm 99.9% sure that's aftermarket with a Ferrari sticker on it.
  6. tazandjan
    39,298
    Ferrari did not fit immobilizers (3 fob system) at the factory until Motronic 5.2 showed up in the F355, 550 and 456 in CY 96 at earliest. I would contact Pozzi and see what they say.
  7. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,041
    Indio Ca/ Alberta
    Grant
    That is an after market alarm. Not sure what kind but you will need to find it so you can identify hiw to fix or remove it.
  8. martinperry
    martinperry Karting
    Jun 4, 2008
    127
    Sawbridgeworth, UK
    Martin Perry
    Thanks everyone!
    At least knowing its not some ECU related system, I should be able to get a local specialist to come around and rip the bloody thing out!!
  9. WATSON
    23,866
    WI
    That's a good plan. Wish us 5.2 guys could do the same.
  10. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    #10 Dave rocks, Feb 22, 2017
  11. Qavion
    Qavion F1 World Champ
    14,470
    Ian Riddell
    A 348 owner had a similar issue here... starter motor cranking, but no start.
    http://www.ferrarichat.com/forum/348-355-sponsored-bradan/543737-348-startup-problem.html
    The alarm was wired into the blue wire off the ignition switch. He just cut the wires off the alarm and re-united the ends of the blue wire. Looking at the F355 wiring diagrams, there is similar blue wiring off the ignition switch, but there is no guarantee your aftermarket alarm is wired up the same way.
    Perhaps best left to the experts. Anyway, please let us know how you go (Perhaps you can ask the expert how it was wired in?). There may be a simple fix for the existing alarm (like a replacing a flat backup battery).
    Cheers.
  12. WATSON
    23,866
    WI
    That is a back-up plan worth considering. I personally followed that whole thread closely as i seriously considered doing that.
    Just wish there as a way to pull the whole immobilizer out. By pass the proper inputs on the ECU and be done with it.
    Of course, you can always just wire the door switch so alarm never turns on....I guess.
