F355 ITB vacuum leak | FerrariChat
Discussion in 'Technical Q&A' started by SoCal1, May 17, 2016.
  1. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    #1 SoCal1, May 17, 2016
    Hi all
    Not a pro with the 355 motor by any means
    I been running down some gremlins and one I found was the ITBs have a serious vacuum leak on the butterfly shaft where it connects to the throttle linkage Red arrows
    I do have some excessive play on the shaft also, Green arrow.
    On the far end of the shaft play seems to be good with no leaks (smoke test)
    How much is "acceptable " and who repairs or modify s these things to 20th Ceentury standards with possible a seal and bushing.
    With this vacuum leak I just don't see it possible to sync the ITB's
    Any thoughts suggestions greatly appreciated
  2. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,468
    Dumpster Fire #31
    SMG
    It's been a long time since I've had one of those apart. How did you determine it was there? only asking as the needle valves in the adjacent ports tend to be the culprit more often then not. I trying to recall if there actually is a seal of some kind there, I think it's just a bronze bushing.
    I know BMW has moved to double sealed needle bearings in their TB's but the buggers are pricey avg $10 a pop sold in lots of 10. so about $100 for tiny little bearings. Given the small clearance heavy grease should work fine under the backing washer.
    doesn't really help I know.
  3. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    I will have to check as I have a set off but it seems unlikely it's anything more than a bronze (oilite) bushing as I don't remeber any resistance that would come from an O- Ring
  4. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    I smoke tested the intake and it looked like Cheech and Chong were in there so much came out
    I would not be surprised if it had nothing LOL :)
  5. Prugna
    Prugna Formula 3
    Nov 13, 2014
    2,005
    Northern California
    #5 Prugna, May 17, 2016
    I will put this in terms for the understanding of a person who names their location "lions drag strip". =)
    First, probably nothing to worry about. You MAY need to recenter that butterfly, but highly unlikely.
    Different than carbs:
    The throttle plates are not "open" to allow air to bypass for idle. The idle air comes in through 1 or 2 computer controlled idle air valves (typical). The only reason there are throttle plate stops is to prevent hesitation at the teeniest tiniest throttle opening. Even smaller movement than "cracking the throttle". Just enough preload to keep the plates from getting sucked down when the car is idling (high vacuum). This why they need to be set and then reset whilst the engine is ticking over.
    The bypass screws are not idle mixture or anything similar. They are just fine tuning a leak, plus or minus from all of the leakage that you already have. For example, on your leaky shaft hole (hehe), the screw will likely be turned in more than the other 7, so that the leakage is equal in all 8. This is what the manometer is for.
    Setting the 4 on one bank: these should all crack at once.
    Setting the other 4: these should all crack at once.
    Setting the banks to each other via the cross shafts: all 8 crack.
    The idle air controller (1996-99) or controllerS (1995) will compensate and set idle speed within a minute or two, after every adjustment. (or 5 minutes, depends on what mood it in and how hot the MAF wires are)
    The procedure is written up in ONE of the F355 owners manual. I belive it is not in the first one, but IIRC is in the LAST F355 manual, which may even be Spider only, my memory is blurred by working hard today. Whichever it is, it is applicable to your car.
  6. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    LOL Yeah, last carb I saw was in late 79 or so :)
    I did go through the procedure of setting mercury per hole, thats what brought me to smoking it. I do have a spare ITB set here that is better then the one on this car BUTT on its way to be flopping around also.
    Just trying to get my ducks in a row and get these butterflies doing what they did when close to new.
  7. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    Tim
    I have eight brand new rubber air box o/rings #14563 they list at $31.46 each not kidding..lol. I would replace them if you have gone this far.I will send you all eight for $100.00
    Michael
  8. Cribbj
    Cribbj Formula 3
    Tim, I would do a search for people who rebuild SU & Stromberg carbs for old Jags, etc. Resealing worn throttle shafts used to be a big business for them.
  9. Tire Fryer
    Tire Fryer Karting
    Feb 18, 2013
    154
    Farmers Branch, TX
    Christopher Williams
    I clicked to say this also. You may want to try Joe Curto in NY. He does a ton of SU carb work, and if he can't help with the throttles, may possibly know someone who can.
  10. North bay tech
    Apr 18, 2015
    22
    Fountain Hills, AZ
    Josh Bare
    I agree with Cribbj, find a good carb guy and get it rebushed. It's a vacuum leak, it'll cause problems and contrary to what some other are saying it is a big deal. The adjustment ports are for tuning... not compensating for a problem. I would recommend getting in touch with Pierce Manifolds. Authentic Weber Carbs, Manifolds, Conversion Kits, Accessories and More! If they can't repair it they may be able to point you to someone who does.
  11. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    Sounds good to me
    Pm me I can paypal
    Sent from my SCH-I605 using Tapatalk
  12. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    Thanks Guys!!!!
    I'm exploring several different approaches to this. Not cornered into just Ferrari parts with an open mind
  13. GatedF355GTB
    GatedF355GTB Karting
    Dec 5, 2017
    227
    SF Bay Area
    Joe
    Resurrecting this thread as it appears I may have a leak at the TB shaft. It's hard to tell though.
    Tim, did you bother to get the TBs re-bushed and if so, by whom?
  14. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    That was many many moons ago, 2016. I had some made at a machine shop. Guy is long retired now. Was not hard at all
  15. GatedF355GTB
    Dec 5, 2017
    227
    SF Bay Area
    Joe
    Excellent. Thank you
