Could someone please clarify the recommended jack points both front and rear for use with a single floor jack or a four arm lift? Thanks, GS Lee
Hey GS, The jack points on a 355 are the same as on a 348. If you look under the car, just past were the door closes shut, you will see the jack point. The one for the front, is in about the same area near the door hindge. They look like raised metal bumps.
