F355 max milage limit | FerrariChat
Discussion in '348/355' started by Klas, Aug 12, 2018.
  1. Klas
    Klas Formula Junior
    Mar 17, 2014
    364
    Gothenburg, Sweden
    Klas Nilsson
    What is the maximum milage you can expect from a Ferrari engine? Most owners and others are very concerned about keeping as low milage of the cars as possible. The value of the car is very much linked to the milage, much more than all other factors. Also a lot more compared to most other cars i.e. Porsche etc.
    My F355 (manual gear) now has 56k miles (90k km here in Europe) on the odo-meter. Should I be worried that my engine soon will reach the end of life and the next step is total renovation?
    Of course the maintenance program is followed strictly.
    Any thought or expereiences of high milage?
  2. ttforcefed
    ttforcefed F1 World Champ
    19,259
    i dont see why it wont go to 150k miles and beyond
    Yassa and Jon Von Bon like this.
  3. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    taking the miles/value equation out of the picture.. I think the 355 engine itself can take indefinite miles.. as long as its well maintained..
    oil, fluids, spark plugs, clean the injectors every major etc..
    however that does not mean other components will not break along the way.. water pump, radiator fans.
    I think one of the highest reported was at something like 150k miles..
  4. Mmckee
    Mmckee Formula 3
    BANNED Silver Subscribed
    Sep 30, 2016
    2,339
    Alta Loma, Ca
    That’s my goal: 150,000
    Yassa and Enzojr like this.
  5. Enzojr
    Enzojr F1 World Champ
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    I seem to be the slacker :)
    Coming up quick on 42,000.
  6. crinoid
    crinoid F1 Veteran
    9,977
    LaCrinoid
  7. GTUnit
    GTUnit Karting
    May 25, 2014
    143
    Socal
    Jack
    Peoples "perceptions" are sometimes based on misunderstandings or lack of knowledge.
    F355 engine does not do well when not run for long periods of time. That and proper maintenance (resolving issues promptly) will ensure the engine lasts for a very long time.
    The nikasil coating in the bores EXTREMELY durable compared to a standard iron/steel cylinder liner in most engines. For this reason alone these engines should last far longer then most as far as cylinder and ring wear is concerned.
    I think many people buy these cars as a Collectors Car that they drive once in a while. This mindset seems to drive the valuation.
    If you understand the cars and buy them to drive and not collect then thats a different story but since everyone wants a higher sale price/valuation then the collector mindset seems to drive the market price.
  8. khcompt
    khcompt Karting
    55
    Halifax, Canada
    Ken Compton
    I just passed the 50k (miles) milestone last week. I bought the car early 2015 with 44300 miles on the clock. I wanted a 355 to drive so searched out a higher mileage car with recent major completed and the known 355 issues resolved. This is my first Ferrari so I was nervous about maintaining it as I am not close to a Ferrari shop. So far apart from regular maintenance the only issues I have had are -
    1. Replace failed cooling fan fuses once.
    2. New battery (one cell in the old one failed.)
    3. Precautionary replacement of the F1 pump relay.
    4. Replaced 1 broken anti vibration mount on the left air intake filter boxe and on the air duct.
    5. Replaced the original 82 deg C. thermostat with an 87 C deg. unit to increase the engine operating temperature to 175-190 F (cool Canadian weather)
    No leaks, always starts. all systems, including the roof work. Motor pulls like hell when the revs pass 6k and sounds fantastic!!
    So far so good.
    Ken
    PS. I saw a post on FC last year of a 355 with +167K miles on it in the UK. Hope she is still running strong.
  9. flat_plane_eddie
    flat_plane_eddie F1 Rookie
    Owner Regional Sponsor
    Mar 30, 2013
    3,168
    DC
    Eddie
    My guess, based on what I've seen here and on for sale ads, is around 70-100k miles before an overhaul is required. That's for the average car; the 355 engine is a high revving engine which isn't good for longevity but great for excitement.
  10. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    761
    Vermont
    john truskowski
    I agree with your statement in that it really has more to do with how the engine is used. If the tach spends more time above 6k the earlier you will need to tear it down. I would think that if it is moderately driven, but somewhat regularly the engine should last well past 100k before oil consumption becomes a problem. And that is of course considering regular servicing using high quality oil.
  11. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,026
    NE FL
    Ken
    Most critical engine wear happens at startup when there is no oil in the bearings. The longer the car sits, the longer time between starts, the more damage. I'd rather have a car that was driven a few times a week with higher miles than one thats sat for weeks and months between starts with low miles.
    As for RPM relating to wear, you're primarily taking about rings. These cars dont have a real overdrive. My c6 z06 cruised around at 1700 rpm. The 355 is always 3k-4k. I would imagine a 355 with 50k miles has had twice the engine rotations of a corvette with 50k miles etc. Trips to 8500rpm do not hurt it in any way in my opinion. Like mentioned before, the 355 engine has very good rings and cylinders.
    I'd been very curious if anyones had any compression issues actually related to bad rings. I would bet carbon buildup on the valve seats from lack of good use causes more compression problems.
  12. redwedge
    redwedge Formula Junior
    Sep 30, 2012
    467
    London
    Steve C
    Some years ago, I put my 355 up for sale. I found a buyer and agreed a price, subject to a PPI, which was performed at the buyer's cost. The inspecting garage found low compression on one cylinder (20psi down, IIRC) and the buyer understandably pulled out, while I contemplated the cost of a rebuild. I drove the car home, picturing pound notes flying out of my wallet and, some months later, eventually got around to having the engine sorted out. The previous low compression reading was no longer present! Where am I going with this... the garage that performed the PPI, who are very respected here in the UK, said they'd previously seen a similar reading on a 355, which turned out to be a bad liner and rings, due to bore wash caused by driving the car when it was only firing on seven cylinders. So, it does happen.
    I do wonder how many people rebuild a Ferrari engine purely because the compression numbers aren't quite there, rather than because there are actual symptoms present - misfiring, lack of power etc. I was about to do the very same thing myself.
  13. flat_plane_eddie
    Mar 30, 2013
    3,168
    DC
    Eddie
    Trips to 8,500 RPM definitely hurt any engine, regardless of whether it has very good rings and cylinders or not. More RPMs is more wear, simple as that.
    jjtjr likes this.
  14. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,737
    Yes and no.
    8500 RPMs before the oil is warn hurts the engine.
    8500 RPMs with the oil over 275ºF will slowly harm the engine.
    8500 RPMs with the oil at 210ºF does minimal harm.
    taz355, INTMD8 and 308 GTB like this.
