F355 puked it's coolant out. Hose? | FerrariChat
Discussion in '348/355' started by Eric C, Oct 18, 2014.
  1. Eric C
    Eric C F1 World Champ
    11,136
    St. Louis, MO
    Eric
    Caught it before anything happened. It's had both rads replaced and it looks like it's coming from the middle front of the engine. Could it be a rad hose?
    Writing as I wait for a tow.
    No doom and gloom please, I know better.
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,673
    San Carlos, CA
    Mitchell Le
    that, or a water pump
  3. Eric C
    11,136
    St. Louis, MO
    Eric
    I've had leaky water pumps before. I can't imagine a pump dumping it all out like this, unless it fell off :)
  4. plugzit
    plugzit F1 Veteran
    7,793
    Redondo Beach, CA
    Bruce Bogart
    #4 plugzit, Oct 18, 2014
    Undoubtedly the water pump fell off, dropped the cambelt, bent the valves, holed the pistons, bent the rods, scored the crank, broke the trans, flatspotted the tires. Car is now junk. But, since I'm your friend, I'll help you out by giving you $100 for what's left! (followed by long discourse about somebody's incompetence, what you should do about it, and why I'm so smart......modesty is one of my best qualities)
    'course, it's probably just a hose.
  5. ClydeM
    ClydeM F1 World Champ
    12,093
    Wayne, NJ
    Clyde E. McMurdy
    I had something similar.
    A loose hose clamp from the last major between the two rads.
    Mine was not obvious & took a while to find.
    Check all your clamps from rad to rad.
  6. redzone
    redzone Formula 3
    Mar 31, 2007
    1,218
    Beach
    Sorry to hear that, good luck.
  7. fatbillybob
    Aug 10, 2002
    29,272
    socal
    You forgot cracked the block that's why it is leaking.
    Eric when were the rads changed? Do you have some miles on the new set-up or has the car been working well for a while?
  8. Enzojr
    Enzojr F1 World Champ
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    DAMN all that stuff Plugzit mentioned AND a cracked block, what's the vin so none of us buy it.
    We will all be praying for a hose clamp, a cheap fix is always preferred.
  9. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Maybe you peed yourself and blaming it on the car?
  10. driveitdaily
    driveitdaily Formula 3
    Jul 20, 2013
    1,041
    lake ariel pennsylva
    john
    Maybe the car puked because it now knows its stuck with the black wheels since you put the nice wheels for sale.
  11. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    949
    Europa
    Bob
    Ok. I'll give you some light relief: my bet is a hose has rubbed against a pulley up front and has worn through.
    The tow will cost more than the repair.
    That or it's what the others said. ;)
  12. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    When I got my car it had coolant leaks. I took it to classic coach on their tech day and the clamp on the hose on the front of the engine was not on correctly. The guy that did the major didn't get the clamp over the flange on the pipe. It was squeezing the hose but not the stub.
    They told me that what happened to you would have happened very soon. Hopefully that's all your dealing with.
    Need to remove the coolant reservoir and maybe the deck, lay on the engine and you can just about get to those clamps
    Good luck.
  13. PaulK
    PaulK F1 Rookie
    4,801
    Michigan
    Paul
    Best wishes to getting this resolved quick and painless. Please do let us know how it panned out.
  14. WATSON
    23,933
    WI
    I knew It! These car are worthless pieces of ****. Why we spent more than $1000 to buy one is unknown. We are all saps. When were the belts last changed? You probably wrecked the engine. Scrap value for sure :) :) :)
    I kid of course.
    My water pump seal is shot and will be replaced this winter. After long drives it spits out a 1/2 cup of water over night.
    What you described may be what caused my water pump problem though.
    The previous engine out mechanic decided that a screwdriver was a great tool to pry hoses onto the connections. He semi punctured a hose and it blew out on the highway.....excellent display for my freeway companions as I had a rooster tail. *sigh*
    Made it home, but the water pump cavity went dry and cooked the water pump seal. I replaced the hose but the smell of coolant was evident and after a year turned into my current leak.
    Best of luck
  15. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    More than ten places it could be leaking in that area. I've had issues with aftermarket hoses developing leaks. Might be just a clamp.
  16. Eric C
    11,136
    St. Louis, MO
    Eric
    Is from top the only way to access those hoses? Not from the bottom?
  17. JeffBarber
    JeffBarber Karting
    Feb 6, 2011
    175
    Lascassas, TN
    Jeff
    Rent a coolant system pressure tester from Advance Auto. Screw it into the res and pump it up.
  18. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    That was how they confirmed mine.
    The hoses connections are high upmon the front of the engine so approach from the top is correct.
    Find a pic of engine out from the front to see where they are.
  19. Eric C
    11,136
    St. Louis, MO
    Eric
    Source for a coolant pressure adapter?
  20. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    My laugh for the day! The pressure test sounds like THE answer producer. Good luck, Eric.
  21. Eric C
    11,136
    St. Louis, MO
    Eric
    #22 Eric C, Oct 19, 2014
  22. Eric C
    11,136
    St. Louis, MO
    Eric
    #23 Eric C, Oct 19, 2014
    ShineKen likes this.
  23. Eric C
    11,136
    St. Louis, MO
    Eric
    Anyhow, pressure tester worked perfect. New hose installed. No leaks. It was a pita to get too. Hands all pretty mangled.
  24. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Glad you got it nailed!
