F355 puked it's coolant out. Hose? | Page 2 | FerrariChat
Discussion in '348/355' started by Eric C, Oct 18, 2014.
  1. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Good job. Where is that hose. To/from?
  2. Eric C
    Eric C F1 World Champ
    11,136
    St. Louis, MO
    Eric
    From the coolant tank to the water pump.
  3. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    Darn.
    I guess I won't be buying a 355 for $100 now.
    Glad it was a relatively easy fix, as most fixes on these cars are.
    That, or I'm not as good forecasting gloom and doom as I need to be! :)
  4. ClydeM
    ClydeM F1 World Champ
    12,245
    Wayne, NJ
    Clyde E. McMurdy
    ROFLMAO! Where's Rube Goldberg? This is a prize winner.
  5. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    Eric,
    Very glad you managed to catch it in time. (Machinery does talk to you - if you're willing to listen.) Was the problem the hose itself, or an attachment issue?
  6. Eric C
    11,136
    St. Louis, MO
    Eric
    It was the hose itself. The edge of the clamp had sliced into the hose. That little 7mm clamp was a pain to get to. Would have been a lot easier if I had removed the powering steering reservoir, but I didn't want another mess to clean up.
  7. Eric C
    11,136
    St. Louis, MO
    Eric
    #32 Eric C, Oct 20, 2014
    Here is the hose that split. It looks like a simple swap, but the power steering reservoir and fuel lines were right in the way.
  8. F1moving
    F1moving Formula Junior
    781
    BUCKeYe!
    Marcus
    LOL
  9. fatbillybob
    Aug 10, 2002
    29,435
    socal
    Look on the bright side Bruce...Eric just designed a tool that can double as a sex toy for you.
  10. Eric C
    11,136
    St. Louis, MO
    Eric
    Multi purpose penis pump, also ribbed for his pleasure.
  11. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    Looks to be about the right size.
    I'm in.....uhhhh wait a minute, let me rephrase that.....I'll take one!
  12. Rifledriver
    37,353
    Very common. Those hoses go regularly. I use Daves hose for those 2 on every car through the shop. Nothing else survives there.
  13. Eric C
    11,136
    St. Louis, MO
    Eric
    What is Daves hose?
  14. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,995
    Northeast U.S.
    Jim
    I think he is talking about hoses from Dave Helm's Scuderia Rampante.
  15. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Those two little hoses should be replaced by every 355 owner ....... here is a good one from mcmaster carr: McMaster-Carr
    The vacuum rating means it will not collapse ... ;)
  16. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,490
    Tucson, Arizona, USA
    Robb
    Dave Helms at Scuderia Rampante. Boulder, CO. Has all the industrial strength hoses.
    Robb
  17. uzername
    uzername Rookie
    Aug 12, 2014
    5
    Just a heads up for anyone looking for the actual adapter for the pressure tester. I haven't been able to find one. Snap-On doesn't even seem to make one. But they do make one for Lamborghini and others. So, making a setup like Eric_C did may be the only option. If anyone knows who makes the adapter, I would like to know.
  18. Shootfighter65
    Shootfighter65 Formula 3
    May 13, 2014
    1,372
    Charleston SC
    Randy..alluneedtokno
    speaking of block and leaking coolant.....does a 355 block have soft plugs? BTW this thread is hilarious except for Erics leaking coolant hope its an inexpensive fix.
  19. Eric C
    11,136
    St. Louis, MO
    Eric
    I had it fixed within 2 hours. I had some spare coolant hose that I was able to use, so it ended up being a free fix.
  20. ClydeM
    12,245
    Wayne, NJ
    Clyde E. McMurdy
    I was just back under the hood & found the same problem hose. It seems the clamp was loose & looks like it cut into the hose.
    However, I happened to cut the hose in two. I noticed the inner diameter is *way* smaller than the nipple connection ends. Is this normal? I'd expect some expansion as the hose had to situate over the nipple. But this much?
  21. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,701
    San Carlos, CA
    Mitchell Le
    Yes, even more than that to the point of almost closing up. Way past its prime, shall we agree?
