F355 radio is dead | FerrariChat
F355 radio is dead
Discussion in '348/355' started by alarcidy, Apr 18, 2009.
  1. alarcidy
    alarcidy Rookie
    Apr 15, 2008
    3
    Radio stopped working after battery was drained (and recharged). Any ideas??
  2. GuyIncognito
    99,703
    does it have a factory code that must be entered to get it to work again?
  3. niklas
    niklas Formula 3
    Apr 25, 2008
    1,535
    Chilliwack BC
    N. Olafsson
    no need for a radio when you've got that beautiful v8!
    (I'm sorry I couldn't be anymore help:()
  4. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,956
    MD and NE
    Robbie
    I think only the later Becker's had the PIN code for the radio...
  5. sclja
    sclja Formula Junior
    392
    San Diego Ca
    Scott Cairncross
    #5 sclja, Apr 19, 2009
  6. KKSBA
    KKSBA F1 World Champ
    15,289
    SBarbara-La Jolla CA
    KKSBA
    Check the fuse for the radio if it is completely dead. Main fuseblock, and if it is good, pull the radio and see if it has an inline fuse or one built onto the back of the radio. While your back there check that there is 12V getting to the radio when the key is on to rule out radio failure or not.
  7. alarcidy
    alarcidy Rookie
    Apr 15, 2008
    3
    The radio has no power and can not enter code.
  8. alarcidy
    alarcidy Rookie
    Apr 15, 2008
    3
    Thank you. The main fuse block radio fuse appears to be fine, I will attempt to remove radio from dash and check if any additional fuses.
  9. sal123
    sal123 Rookie
    Dec 1, 2008
    33
    i have seen this before, unplug the power from the the radio for a few minutes & try again.
  10. bmwguy54
    bmwguy54 Rookie
    Mar 5, 2015
    40
    So a latter day update. The Ferrari radio, it says so when it turns on, is also a cassette player. I've never tried the tape feature, as using an old model like this is a good way to break the rubber bands that reside therein. The radio recently stopped working; it wouldn't respond to the on button at all. The unit was getting power, as the little red anti-theft light would blink. Fuse wasn't blown; I checked. So in some desperation I opened the rather comical face plate to reveal the cassette opening, and reclosed it. The radio started working! I can only assume that the contact that tells the unit that the cassette feature is not being used was in need of cycling and reestablishing contact. I have a new expression, as this is a Spyder. "As worthless as a radio in a Ferrari." I never use it.
    ShineKen, INRange and Qavion like this.
  11. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,212
    CT
    John Kreskovsky
    This turned out to be my problem for the Sony Ferrari radio..
    KKSBA likes this.
  12. brogenville
    brogenville Formula 3
    2,252
    Robin
    This video was amazing! I had the no power problem as well, and thanks to the video I wa able to find the broken track under a capacitor and installed a little jumper to bypass the break. The lovely old original stereo would have been junk without this video!
