F355 Radio wiring help needed | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by DanRC30, Feb 1, 2025.
  1. RayJohns
    RayJohns F1 Veteran
    7,953
    West Coast
    Ray
  2. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    #27 DanRC30, Feb 3, 2025
    Yes, they are all in there, so I can carefully solder them back together. I can do the same with the other side that goes to the radio as well. I didn't even know what the connector looked like so your pictures were invaluable to solving this problem. I also didn't know that there needs to be a 15a fuse in the yellow wire between the radio and the connector. I'll order one of those and splice it in. It also looks like the red wire gets a 3a fuse, but that goes to the unused connector. Confirm I'm correct?
    Then all I have to figure out is what that speaker wire is and the cut yellow wire in the dash that doesn't seem to go to the radio.
  3. Qavion
    Qavion F1 World Champ
    14,635
    Ian Riddell
    RayJohns and DanRC30 like this.
  4. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    What's REMOTE IN for?
  5. Qavion
    14,635
    Ian Riddell
    #30 Qavion, Feb 3, 2025
    Double check this. On my car, there is a yellow wire (presumably ACC power from the ignition switch) spliced into two red wires. One red wire goes to the unused plug, and the other red wire goes through the 3amp fuse to the Sony backplug (pin2). The unused plug doesn't seem to be fused.
  6. Qavion
    14,635
    Ian Riddell
    Maybe Ray knows... I don't have anything plugged into my REMOTE IN.
  7. Qavion
    14,635
    Ian Riddell
    Those yellow wires are a real rats' nest. I may have to cut some zip ties to figure out what feeds what.
  8. RayJohns
    RayJohns F1 Veteran
    7,953
    West Coast
    Ray
    That should be for the Sony RM-X4S "wired remote" thing. It's kinda like an after market remote that sort of mimics modern steering wheel controls.
    Ray
    Qavion likes this.
  9. Qavion
    14,635
    Ian Riddell
    It's important to note that the grey/red wire is live battery power (powered by fuse 4 in the frunk) and is fed to pin 1 of the Sony unit.
  10. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    On one of the diagrams that was posted (reposted below), it showed two fuses... one 15a and one 3a. The 3a goes (I THINK) to the unused plug. Confirm?
  11. RayJohns
    RayJohns F1 Veteran
    7,953
    West Coast
    Ray
    This video shows it pretty well. That blue 3.5mm plug back there should have a slight chamfer to it I believe.
    Ray
  12. RayJohns
    RayJohns F1 Veteran
    7,953
    West Coast
    Ray
    It's also important to note that you should always disconnect your battery when working on your car's electrical system :)
    Ray
  13. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    #38 DanRC30, Feb 3, 2025
    I'm using the battery shutoff switch under the hood by the CD changer. That should be sufficient, no?
    Qavion and RayJohns like this.
  14. RayJohns
    RayJohns F1 Veteran
    7,953
    West Coast
    Ray
    Yeah, that should be fine.
    Ray
    DanRC30 likes this.
  15. Qavion
    14,635
    Ian Riddell
    There is something weird going on here. I cut the zip ties to get better access to the wiring and the wires didn't go where I thought they did.
    My installation doesn't match the Sony diagrams. I have live battery power on pin 2 of the Sony plug (not Acc as shown in the Sony manual). I checked that with a multimeter. I know my radio was working some time ago and I haven't touched the wiring. The yellow wires which feed both pin 1 and 2 ultimately end up at a mysterious box with a fuseholder on it.
    I can't say I've seen this box before or know what it does. Fuse 4 in the frunk feeds pin 3 of connector 59014 (7 pin plug). The wire colour changes from grey/red to yellow at the plug. The yellow wire goes to a splice. From here, it goes to:
    1) Pin 2 of the Sony unit, via the 3A fuse. The splice also feeds the unused connector
    2) the mystery black box with a fuseholder on it.
    Sorry that the yellow wires are hard to see.
    The yellow wire coming out of the mystery black box goes to pin 1 of the Sony unit. Since the black box has no other inputs, I'm not sure what is supposed to be coming out of the black box. I was unable to take a voltage reading on pin 1 of the Sony unit. It was neither live battery or accessory volts. I can't figure out how the Sony unit turns on/off.
  16. Qavion
    14,635
    Ian Riddell
    Probably just finger trouble... I checked again and both pins 1 & 2 have live battery volts. The mystery box was just a low pass filter/RF choke for the power into pin 1 of the Sony unit.
    I guess the unit stays on all the time (???) unless you turn it off. Or my car is wired up incorrectly.
  17. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    I am missing that black box. Where would I find that?
  18. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
  19. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    Update: I did some soldering...
    Need to figure out the red wire fuse and the box with fuse on the yellow wire. Then the harness should be done.
    Then I can solder in the connector to the car. Then figure out what the cut yellow wires and the speaker wire is behind the dash.
    Qavion likes this.
  20. Qavion
    14,635
    Ian Riddell
    #45 Qavion, Feb 4, 2025
    If you solder/crimp the wiring on plug 59014 (7 pin) to the endcapped wiring on your car, that would have hooked the Sony unit to the speakers, but I can't even imagine what kind of speaker wiring has been removed/added to your car. There should be 4 speaker wires, so I'm not sure of the function of that single wire in your photo.
    Here's the speaker wiring diagram for a 5.2 car:
    https://www.dropbox.com/t/GbebNDaGwAfUeRGS
    (see bottom of diagram for plug 59014). Link expires in 6 days.
    As a short term measure, you may be able to crimp the two yellow wires together until you find a replacement filter. I could find no part numbers on my filter. It looks original and the wires are properly soldered to the filter (inside the unit). I'll have to fish around in the parts manual to see if I can find it, but I guess any low pass/RF filter from an audio store can be used. My unit was sandwiched between the Window ECU and the radio, so right where your yellow wires were cut. Mine was clamped into position with a bracket screwed onto one of the dash support brackets, but I don't know if you have the equivalent on a LHD car. The clamping bracket looks like a rectangular metal P clip.
  21. Qavion
    14,635
    Ian Riddell
  22. Qavion
    14,635
    Ian Riddell
    By the way, there appears to be other speaker wires in your earlier photos:
    What pin number on the Sony plug does the speaker wire with the red splice go to? It looks like it goes to either pin 1 or 2 or both. They are the DC power pins for the Sony unit, not speaker outputs.
    You need at least two speaker wires for each side (LH/RH) on the standard setup... i.e. a total of 4. You can't run your car's speakers on 1 wire.
  23. Qavion
    14,635
    Ian Riddell
    Do you know what kind of radio/stereo the PO fitted (or tried to fit)? I suppose the aftermarket radio may have had a different pin configuration. Even so, if the red splice in your photo is joining pins 1 & 2, that's definitely not a speaker wire.
  24. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    When I say it's a speaker wire, I'm only defining the wire, not what it's used for. It's likely just being used as a regular power wire, but I don't know for sure. Haven't put a meter on it yet, and I can't see where it goes.
    My friend who I bought the car from is going to try to locate the aftermarket unit tonight. He's positive he has it, just needs to find it. there's always a chance that the fused filter box is on that radio. Keeping fingers crossed.
    As far as speaker wires go in the dash, yes, they're there and I will be soldering back in the factory connector 59014.
    The other speaker wires you reference that are cut and sticking out of the dash were just spliced in by that P/O. I'll be cutting them off so I can solder 59014 back on. The one wire that confuses me is the one that runs under the dash and by the yellow wires that are cut and left hanging deep in the dash. Those yellow wires MAY have been connected and were originally one wire. It's nearly impossible to tell, but I can tell you this.... there is a small zip tie holding them together. If you look closely in the pic you can see it. Maybe someone can do what I did and slide themselves under the dash and take a look? It's right by the OBD port.
  25. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    I cut the splices pieces off in the car and took a pic of the wires I'm working with, except for the one mystery yellow wire noted in my previous response. See pic...
