F355 Radio wiring help needed | Page 4 | FerrariChat
Discussion in 'Technical Q&A' started by DanRC30, Feb 1, 2025.
  1. Qavion
    Qavion F1 World Champ
    14,635
    Ian Riddell
    #76 Qavion, Feb 5, 2025
    If the speaker wire is being used for power, I would make sure that it's either encapped (with a non conductive covering) or the entire wire is removed.
    I don't know if that speaker wires uses power from frunk fuse 4, but I'd make sure that you have a fuse there.
    DanRC30 likes this.
  2. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    It's on the river's side of the console opening. I could barely get my 1' long extension in there to take the nut off. I can try to take a pic after I install the harness. I'll post it up if it looks decent.
    Thanks for all the help. Keeping fingers crossed that everything works!
    Qavion likes this.
  3. Qavion
    14,635
    Ian Riddell
    Mine too. Let me know .... so I can put my car back together :D
  4. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    This is the best pic I could get! Super tight in there!
    Qavion likes this.
  5. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    So it worked for a few minutes, but then the right side sound faded away and shortly after that, the left side faded away too. I'm guessing that the unit needs repair and that's why the radio was swapped out. I could do the same thing but I'd buy an adapter instead of cutting everything up. Or have the radio repaired somehow.
    It does turn on and off with the key out of the ignition. I assume that's the same with other people's cars.....?
  6. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    I just tried it again and now it's working. It's like the volume buttons need to be cleaned or something because it gets scratchy like those old school knobs that we get scratchy from sitting around for a long time. I guess time will tell.....
  7. Qavion
    14,635
    Ian Riddell
    I would ask this question on the 348/355 forum. I just put mine back together and it operates as I thought it would (with that wiring). i.e. It remains powered when the key is off. I had to use the power button to turn it off. Well, the display worked... not much else. I may have to retune the radio or find some CDs/tapes. If all else fails, I'll have to read the manual :D
    I assume all the installations are done at the dealers, so maybe my dealer messed up the wiring?
  8. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    Why would the radio be installed at the dealer and not the factory?
  9. Qavion
    14,635
    Ian Riddell
    I just assumed because the harness is not shown in the parts manual. The OEM wiring diagrams don't show the installations either (only up to connector 59014). Some 355's have a Becker radio as standard, but I don't know if that's based on assembly number or market.
    Ugh... everytime I work on my car, I damage something... When I was drawing the radio wiring diagrams on a piece of paper, I didn't notice I was getting pen marks on my white leather. I tried to get it off with some really mild solvent (MAF cleaner), but when that didn't work, I used isopropyl alcohol (Google suggestion)... It rubbed a hole in the leather back to the raw uncoloured leather in a very conspicuous spot :rolleyes:
  10. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    Oh no!!! That's awful! That diagram should be saved somewhere in this forum in a file. I can't be the only one dealing with this issue.
    I was terrified of burning holes in my leather from the soldering iron while soldering that connection back into the dash. I took one of my thick jackets and lined the whole floor with it and the seat just to make sure. Luckily, I didn't do any damage. But it was hairy for sure!
    Qavion likes this.
  11. Qavion
    14,635
    Ian Riddell
    I looked into accessing the ACC wiring near the steering column, but it's not easy to get to, at least on a RHD car.
    I also have an aversion to cutting into power wires and splicing new ones in.
    USA/Canada cars have an 8 slot plug. Other markets have 6. It's to do with the USA/Can cars having a seatbelt buzzer.
  12. Qavion
    14,635
    Ian Riddell
    I think you did an excellent job with those splices. Almost looks factory :D
  13. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    Hey now...I never said I was a professional solderer! :p Honestly, the only difficult one was the last one with three heavy wires. The iron wouldn't get hot enough to melt the solder through and through. But it was enough to hold. At least everything is soldered and shrink wrapped properly and it works! Much thanks to you kind sir!
    Qavion likes this.
