355 - F355 rear mesh recon | FerrariChat
355 F355 rear mesh recon
Discussion in '348/355' started by MikeeB355, Mar 20, 2020.
  1. MikeeB355
    MikeeB355 Karting
    Dec 7, 2019
    82
    S Wales
    Michel Bee
    Ok, I'm bored already so I decided to do something I've been meaning to for a while now. I've removed the mesh panel at the back of the car, the bit with the F355 badge as it was a bit jaded and slightly rusty.
    My question is should I repaint it with a Matt, satin or gloss finish? I'm also toying with the idea of repainting the F355 GTS badge as well, maybe in rosso corsa to make it really stand out.
    Thoughts?
  2. audi_328
    audi_328 F1 Rookie
    2,807
    NH
    Audi
    Always nice to make what's looking weathered and old look new again. I'm more traditionalist than not, so I'd respray the mesh panel as close to the OEM finish as practical, but I'd leave the badge alone. Your car though.
    MikeeB355 likes this.
  3. MikeeB355
    MikeeB355 Karting
    Dec 7, 2019
    82
    S Wales
    Michel Bee
    I ended up spraying it a satin black which left a really nice finish and decided to leave the badge alone. Just need a couple of rivets to finish it off
    audi_328 and Qavion like this.
  4. Qavion
    Qavion F1 World Champ
    14,422
    Ian Riddell
    Did you use paint stripper to remove the old paint? Also, did you apply a primer coat?
  5. MikeeB355
    MikeeB355 Karting
    Dec 7, 2019
    82
    S Wales
    Michel Bee
    I fully degreasedit first, then gave it a light sand and then used a rust preventative black spray paint
    Qavion likes this.
  6. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Can you powdercoat it?
  7. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    you probably could, but getting the paint off completely prior tot he powder would be your challenge. Media blasting it may warp it, you could chemically strip it
  8. malex
    malex Formula 3
    1,249
    FL
    Media blasting could warp it, but it shouldn't assuming the operator is competent. Selecting the right media, depending on the desired finish, and air pressure are key.
    Cerakote is another option. Their air cured coatings are a diy option, with the right gun and safety equipment. I've done it in my garage.
