F355 SECA Manifolds | Page 2 | FerrariChat
F355 SECA Manifolds
Discussion in '348/355' started by SpiceV8, Nov 28, 2012.
  1. SpiceV8
    SpiceV8 Karting
    Apr 10, 2012
    77
    London
    For full spec and more info call Manu as Scuderia systems, he knows all .
  2. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    SoCal LA/OC/New Mexico
    Tim Dee
    Need a SoCal dealer so I can go touch them, I like to touch it first :)
  3. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    First off the manifolds do look great.
    The problem with the factory manifolds is low grade (too thin) stainless steel and heat shields that contain the heat too effectively......resulting in a melted/deformed/blow out mess.
    If these aftermarket manifolds are such a good product (and I'n NOT saying their not) the stainless grade/thickness/warranty should be printed on a web site for all to see.
    Fabspeed comes to mind.....clearly lists this info on their website.
    You should'nt have to call a retailer privately to find out this info.
  4. f355spider
    f355spider F1 World Champ
    18,029
    Well, I would definitely say you found the source of manufacture. ;)
  5. ulf rickard
    ulf rickard Formula Junior
    Sep 28, 2009
    424
    Sweden
    Ulf Rickard
    I´ve just recived prices from X-ost. A set of manifolds cost 3000 EUR all incl.
  6. bryn_p
    bryn_p Rookie
    Jun 3, 2008
    43
    West Lancs, UK
    Bit of an update to this thread from a while ago...
    I've been investigating manifold (header) replacement options and have been in contact with X-ost directly who say they no longer make F355 manifolds. I've also been in touch with Scuderia Systems and the SECA manifolds are available but are £3995 plus VAT at 20%, so the best part of £5000.
    Here's some info from Scuderia Systems on the SECA manifolds:
    "It's worth noting that the Seca Competition Manifold set we supply, were
    actually designed for 355 Challenge cars running the world wide 355
    Challenge series organised by Ferrari some years ago - the whole point of
    them was to increase power AND be reliable. They were designed to last many
    seasons of racing. The fact that they give so much over and above the stock
    manifolds (actually being an performance optimised header) AND they're
    cheaper than the OE parts, make them a great buy - the good news is that
    installation on the Seca manifolds is as straightforward, a non-invasive job
    as replacing the normal manifolds
    More to the point, replacing the 355s stock manifolds with the Seca
    manifolds on both road cars and Challenge Cars is a job that we are doing
    with ever increasing frequency for various 355 owners. The problem lies
    primarily with the quality of the original Ferrari supplied manifold. Put
    simply, they are made with a very thin and low quality stainless steel
    unable to withstand the temperatures within the F355's engine bay. The heat
    generated by the cars running (especially during hard/track/competition use)
    causes the manifold's mild steel to expand... when the car cools (when not
    running) the steel contracts. This continuous cycling of expansion and
    contraction results in minute cracks which eventually widen into full blown
    exhaust manifold failure and an exhaust leak which causes more engine bay
    damage, power loss, and a sound like a tractor!
    The Seca manifolds are actually not replicas of the original Ferrari part.
    They are actually sport manifolds - i.e. beautiful headers optimised to
    reduce exhaust backpressure from colliding exhaust flow pulses from the
    separate exhaust ports on the engine. They are made of thicker AND of much
    higher quality grade 304 stainless steel. Furthermore they are then given a
    very expensive thermal insulation coating to prevent the engine bay as hot
    as it does with the original equipment (which leads to further reliability
    issues).
    There's four reasons why we are selling so many of them:
    1. They will genuinely give your 355 a very definite increase in BHP (and
    also give a fuller, deeper sound).
    They have been backpressure optimised - i.e. exhaust pulses from the
    individual exhaust ports in the engine do NOT collide with each other
    because of the length and shape of the manifold Seca - as a result the
    engine breathes MUCH more freely as the revs climb and particularly with a
    Seca exhaust, it pulls like a freight train to the red line. We've seen some
    41bhp on a Ferrari 360 with these headers and we would expect some 30bhp on
    355 in good shape with a Seca/Capristo exhaust and sport cats on as well...
    2. They make the engine bay run cooler which is essential for hardcore track
    use.
    3. They'll never need to be replaced again (they are under warranty). And
    the road use version contains the air injection rail to assist catalysts in
    coming up to temperature quickly which helps with low emissions and
    emissions testing everywhere.
    4. Furthermore they are cheaper than the pathetic quality original Ferrari
    manifolds.
    The Ferrari manifolds whether new or used are prone to failure and there is
    no reason to suggest that you could be replacing a new set of Ferrari parts
    within a year of putting them on! (this is the typical scenario a Seca
    manifold buyer comes to us with - exasperation"
    Cheers,
    Bryn.
    ShineKen likes this.
  7. Steve355F1
    Steve355F1 F1 World Champ
    Aug 26, 2011
    17,121
    Adelaide, South Aust
    Steve
    Thanks Bryn. Very interesting.
    Would the 20% VAT be applicable to purchasers outside the UK?
  8. bryn_p
    bryn_p Rookie
    Jun 3, 2008
    43
    West Lancs, UK
    No it wouldn't, so quite a decent saving there. I haven't (yet) investigated buying direct from SECA but it may be possible. The price quoted earlier in this thread for these 18 months ago was £2600 inc VAT so I wonder if the increase is from the manufacturer or distributor?
    One other thing I forgot to mention, the spiel from Scuderia Systems states these are cheaper than the factory manifolds when in fact that is no longer the case. I believe the price from Ferrari is now £1735 + VAT each, although I don't know by how much theirs have been improved, if at all.
    Cheers,
    Bryn.
  9. Steve355F1
    Aug 26, 2011
    17,121
    Steve
    Cheers. Still makes them more expensive than Tubi, which unless I'm mistaken are generally seen to be the gold standard in replacement 355 headers.
    They'd want to be BLOODY good to be worth paying that much.
  10. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,119
    Fort Washington, PA
    John S
    #35 Fabspeed Motorsport, Jan 23, 2014
    My only experience with X OST was on 456 Sport catalytic converters, and they were ugly pieces of scrap. Set off a CEL too. We ended up making our own, not because we wanted to get into the 456 market, but because our customer needed a working solution that wasn't the extremely expensive OEM Ferrari parts.
  11. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,007
    Indio Ca/ Alberta
    Grant
    Just to let you guys know my new tubis look just like thos insulated and everything and I think they were 5000. According to tubi gives the same results as above.
  12. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,007
    Indio Ca/ Alberta
    Grant
    #37 taz355, Jan 26, 2014
  13. ronrob
    ronrob Formula Junior
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    Hi Bryn,
    Have you priced Tubi (for a pair) in the UK? I can get a price from Tubi France if you are interested.
    Ron
  14. bryn_p
    bryn_p Rookie
    Jun 3, 2008
    43
    West Lancs, UK
    Hi Ron,
    Thanks for the offer but I've decided to use JP exhausts here in the UK to rebuild my existing manifolds. The cost is around 20% of replacing them and they are only an hour away from me so it seems like a good solution. John at GT Cars in Warrington who looks after my cars recommended them also which is endorsement enough for me!
    Cheers,
    Bryn.
  15. ronrob
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    I had my LHS manifold repaired by JP Exhausts 18 months ago. Quick turn round and good customer service.
    Ron
  16. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Anyone used QV of London to rebuild their OEM 355 manifolds?
  17. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,007
    Indio Ca/ Alberta
    Grant
    Never used them buy have read a thread that they were not happy but many have used them and I have only seen a few that were not happy. We all have to remember that the happy guys don't always post but the not happy guys post every time.
  18. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Can you recall any reasons why those that were unhappy were?
  19. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,827
    Richmond
    Pete
    I think it was that only the bad portions were replaced instead of the complete pipes and subsequent refailure. I think they've since taken the method of completely replacing all pipes and just reusing the flanges and collectors. Do a search, though.
  20. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Hmmmm
    Anyone know anything else about QV of London and their manifolds?
    I had mine done about 6 years ago...but not fitted them on the car.
    I have a set of NAP manifolds....but would like to install the QV's soon.
  21. ronrob
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    I thought that I knew all the TLA's (my invention, Three Letter Acronyms) for manifolds but you have me stumped. What the blazes is a set of NAP manifolds?
  22. F355Bob
    F355Bob Formula 3
    I had a set of QV manifolds a few years back and burned through in 1-2 years. They just replaced small sections of the manifolds, mine were not all new tubes.
  23. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    They're manifolds that i bought in the states about 10 years ago.
    I am sure the firm was NAP ...or something very similar.
    They have springs connecting the tubes to the collector pipe.
    If anyone knows who made them i would be very grateful.
    They are in good order and fit perfectly.
    Think they are ceramic coated on the outside.
    I have the original headers that were renovated 7 years ago by QV and am thinking of fitting them back next engine out service.
  24. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Not good to hear this.
    I have now read others similar.
    It appears though at sometime they began repacing the whole set of pipes...but when?
    Am looking at tubis...but soooo pricey.....3000 pounds + each side thru eurospares!
  25. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Oh.....
    The welding to secure the heat shields back on the QV renovated headers is of a very untidy standard.
