F355 Slow Down Light On | FerrariChat
Discussion in '348/355' started by mpodgor, May 28, 2011.
  1. mpodgor
    mpodgor Formula Junior
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    I just changed the oil. Royal Purple 5W-40. So I go on a little test drive, boom. The Slow Down light comes on. WTF? (Flashes)
    Any ideas? It's a 1999 F355 Spider. I double checked the wiring and all looks good.
    I really can't slow down much when I'm at a stand still.
    HELP!
    Should I just drive it off a cliff????
  2. mowater
    mowater Formula Junior
    May 24, 2004
    362
    drive fast
    let the car work and blow out all the carbon
    works for me every time
    especially the last time when i also just finished an oil
    change :)
  3. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    Yes, you should. Which cliff and what time will you be doing this ?
  4. Rob'Z
    Rob'Z Formula 3
    Mar 29, 2008
    1,024
    Tucson,AZ
    Robert
    I've heard that overfilling the sump can trigger a SDL.
    Rob
  5. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,793
    Henderson, NV
    Roberto Bellezza
    Good point !
  6. Bella Macchina
    Feb 25, 2006
    36
    Naples, Fl / Canada
    Al
    Mine turned out to be exhaust manifold. insulation from the manfold damaged the cat..so that had to be replaced as well. My advise is don't drive it until you find the problem.
  7. f355spider
    f355spider F1 World Champ
    18,055
    SDL is related to the catalyst protection circuit and has nothing to do with over filling the oil or having to drive the car hard to "blow out the carbon". Either you have an overheated catalyst (rare) or a fault in the system ( common). Faults are typically from either a failed catalyst ECU or temperature probe. There are many threads on how to further diagnose the issue, no sense starting over here. Just use the search function in the upper left corner of the page. Try "slow down light" searching specifically in the 348/355 section to narrow the search using "advanced search".
    Good luck.
  8. mk2007al
    mk2007al Rookie
    Jan 1, 2011
    10
    Cologne/Germany
    Michael
    Humidity also could cause the Slow Down module to fail, as the older units are becoming permeable. At least thats what the 348 Slow Down Modules in Europe are best known for.
    They were made from a small italian company called Vescovini and they are obsolete. They shall protect an overheat for the too-small-sized original catalytic converters and the will damage sooner or later - even if the car has not been driven, due to the age and permeability of these modules.
    Any dust, moisture, oil or water can penetrate them and out of the blue the slow down message will be displayed. Maybe i could help a bit. Good luck with your precious.
    cheers,
  9. f355spider
    18,055
    #9 f355spider, May 29, 2011
    Again, I ask the OP to search the threads for relevant information related directly to the 355. All 355s came originally with catalyst ECUs with black epoxy potting and are prone to moisture contamination. The best solution is to replace them all with the later upgraded ones, which are also used on the 360. They can be identified by the green epoxy used. I would recommend NOT purchasing used or new black epoxy ones, as they will only fail, if they arent already bad.
    But again, the OP does not know yet, whether he may actualy have a problem with his catalysts over heating, or bad thermo probes or the catalyst ECUs might be failing.
  10. Labman
    Labman F1 Rookie
    3,803
    Long Island, NY
    Steve
    If you need a new thermo probe I have and extra I can sell you cheap. Replaced mine due to a CEL for the bypass valve and it turned out to be a bad valve not the thermo probe.
