F355 Spider Power Window Question | FerrariChat
Discussion in '348/355' started by Loser, Jan 4, 2010.
  1. Loser
    Loser Formula Junior
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    The power window on my 97 F355 Spider will not move unless the top is locked in the closed (up) position, or I push the sensor up by the drivers sun visor with my finger. Is this normal? Today, I compared it with a 98 F355 Spider on which the windows worked normally with the top down. Also, on my car, the windows automatically roll down about an inch when I release the sensor. On the other car, the windows stayed up all the way.
    I am guessing that my car has an issue. Maybe the sensor that detects that the top has completed its down cycle is bad. Thoughts?
  2. FerrariDeeJay
    FerrariDeeJay Formula Junior
    Jun 2, 2009
    418
    Chino, CA
    Michael
    Does your top open and close normally with no issues?
  3. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    I think so. The seats move automatically for after the down cycle completes.
  4. FerrariDeeJay
    Jun 2, 2009
    418
    Chino, CA
    Michael
    The reason I asked you, is because my windows would not lower automatically when the pump that opens/closes the top was out of oil. Once I had the oil in it everything worked as it should.
  5. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    Sorry, I was trying to respond via my cell in my previous post.
    When I open and close the top, everything seems normal except the window operation.
    When closing, the seats move forward, then the top moves up. I have to pull the top up as it is rising and then latch it in place. Once it is latched, the windows work.
    When opening, I unlatch the top, the windows go down an inch or so, then I push the top back until it beeps. Then I use the switch to lower the top completely. After the top is down, the seats move back to complete the cycle.
    Once the top is unlatched from the windshield, the power windows will no longer operate unless I push on the sensor in the latch receiver while I am operating the windows. Then, if I am rolling up the windows, they will automatically roll down about an inch after I release the sensor.
  6. Future ferrari collector
    Oct 12, 2006
    1,795
    Perhaps that microswitch on the roof frame is sticky rather than faulty. BTW - you shouldn't need to pull the roof to complete the closing cycle, the pump should finish it. Check the oil levels. Only time I need to use my hand is to prevent the roof from slamming onto the roof frame during the last stage of closing the roof.
  7. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    I found the problem. Microswitch Sx (Soft top movement microswitch, pg H-60 in the manuals) was worn. It is located behind the driver's seat (US) in the track for the soft top frame. I bent it slightly to get it to work for now. I will order a new one and replace it. The top and windows work perfectly now. Yay!
  8. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    16 64416800 1 SENSOR $ 195.47
    Wow! $195 for a switch. I guess I'll wait until it wears out completely.
  9. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    #9 Loser, Aug 11, 2013
  10. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    Well, it has now worn out completely. It is time to try to find it for less than $200, or rebuild it.
  11. 97spiderman
    97spiderman Karting
    Dec 15, 2008
    107
    Sunny Buffalo, NY
    JohnAG
    For $200. new, keep us posted with your progress on the rebuild
  12. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,270
    CT
    John Kreskovsky
    Post a picture of the switch. Those are usually pretty common.
  13. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    #13 Loser, May 14, 2016
  14. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    The numbers appear to be BUP65SS and 27795 (or maybe BUP655S)
  15. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    #15 Loser, May 14, 2016
  16. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    #16 Loser, May 14, 2016
    They are $7.75 each. Unfortunately, the minimum order is 1000 at Digikey. I'll have to try to contact the company to get samples on Monday.
  17. Qavion
    Qavion F1 World Champ
    14,436
    Ian Riddell
    Strange.. Some eBay photos of this part number show a roller arm, others don't.
    Are there 3 wires on the old one? (and are they all used?) Does the plug have 2 pins or 3?
  18. Qavion
    14,436
    Ian Riddell
  19. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    Nice find. That may be the exact part. The roller is actually a separate part that attaches via a bracket to the two mounting screws on the switch.
    Sent from my SM-G900V using Tapatalk
    Steve733 likes this.
  20. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    The three wires are so it can sense both states, open and closed, via a voltage level. The lack of voltage would be a fault. I will need to look at the connector again tomorrow to see if all three wires are actually used. I seem to remember that only two wires were used, but I need to confirm.
  21. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    The switch on the car only has two wires. It is a normally open switch. So when the top is down, the switch is closed.
    A three wire switch could be used as well though by just not connecting the wire for the open position.
  22. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
  23. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    Even though the photo shows that the switch has two wires, it in fact has three wires. This shouldn't be a problem though. I just need to determine which wire is not used. I'll post more information once I determine it the switch will fit.
  24. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    I have installed the new switch and it works perfectly. The original switch was a normally closed switch, so I used the grey and black wires on the new switch. The blue wire was the normally open wire, so I just cut it short and put some shrink tubing on it.
  25. Qavion
    14,436
    Ian Riddell
    Thanks for the update. Well done!
