F355 Spider - Seat Problem! | Page 3 | FerrariChat
Discussion in 'Technical Q&A' started by Dem, Jun 12, 2004.
  1. Pepsi10
    Pepsi10 Formula Junior
    Nov 24, 2008
    855
    InlandNorthWest
    Mike M
    Question, about driver’s side seat, it does not move when putting down the roof.
    Some history, my roof has always worked okay. I have to push up on one of the bars during the process (but I will replace the elastic this week, and maybe that minor inconvenience will be solved). Both seats work fine with the switches. However, when I put down the top, the passenger seat moves forward, the driver’s seat does not (likewise at the end of the sequence, the pass seat moves back where it was, the driver’s seat just sits where I left it). So usually I move the driver’s seat forward with the switch. Most of what I read here would say that it is a problem with the pots? But that doesn’t really make sense either, because if the pot was bad, and not giving the system the correct answer about its’ location, wouldn’t the roof not operate?* Any thoughts would be appreciated. As usual with this car, I am pretty happy my problems are minor, but still good to try and fix stuff, even if not critical.
  2. Qavion
    Qavion F1 World Champ
    14,534
    Ian Riddell
    Strange. Can you measure the resistance of the potentiometer with the seat in various positions? If the roof controller thinks the seat is always in the fully forward position, I can understand system allowing roof operation. However, I thought the potentiometer was also required for manual operation... or at least some aspects of it.... I recall some folks saying that you can move the seat by disconnecting the potentiometer completely.
  3. Pepsi10
    Nov 24, 2008
    855
    InlandNorthWest
    Mike M
    Thank you, much appreciated. I will try.
