F355 Spyder Dome light and dome light Round switch Normal Operation | FerrariChat
Discussion in '348/355' started by lemon355, Sep 20, 2025 at 5:43 AM.
  1. lemon355
    lemon355 Karting
    Aug 8, 2009
    239
    Melbourne Australia
    Peter Kay
    #1 lemon355, Sep 20, 2025 at 5:43 AM
    I just want to check with other 355 Spyder owners as to the correct operation of both the dome light (3 position rocker switch) and the shifter console round Dome light button switch
    This Is my understanding of the system after reading the owners manual
    FLAT DOME LIGHT ROCKER PANEL LENS = Light always Off
    ROCKER PANEL LENS FACING FRONT OF VEHICLE = Light illuminates automatically with the Opening and closing of doors.. This is the default position if you want courtesy lights
    ROCKER PANEL LENS FACING REAR OF VEHICLE = Allows you to turn on the dome light with the doors closed.
    SHIFTER ROUND BUTTON SWITCH = Manual control of the Dome light on/off
    Firstly is this correct..?
    Secondly does the shifter console round button work at all times when the light is off ( regardless of postion of roof panel rocker switch) and whether the doors are open or closed an regardless whether the vehicle has key in ACC position or car is off and key out ( but battery still connected of course)
    Any help would be greatly appreciated and thanks in advance..
  2. lemon355
    lemon355 Karting
    Aug 8, 2009
    239
    Melbourne Australia
    Peter Kay
    OK.. So had another look at the system
    FLAT = Light alwaysoff ( regardless of doors/ key position /console shifter switch)
    FRONT OF VEHICLE = Light illuminates automatically with the Opening and closing of doors.. Default position if you want courtesy lights.
    The shifter console switch ONLY works when Rocker panel faces windscren and then only when doors are closed and regardless of whether parkers lights are on or off or key position in ignition barrell
    Can anyone please confirm..?
  3. Qavion
    Qavion F1 World Champ
    14,531
    Ian Riddell
    Confirmed on my 98 Spider.
    The light time delay/dimming on the door closing is provided by the Immobiliser ECU on the 5.2 car. On the 2.7 there is a dedicated dimming module.
  4. lemon355
    lemon355 Karting
    Aug 8, 2009
    239
    Melbourne Australia
    Peter Kay
    Awesome.. Now we have a reference point for all spyder owners out there.. Thumbs up for Ferrarichat!!;)
