F355 Steering Rack Boots - Alternative Found! | FerrariChat
Discussion in '348/355' started by junglistluder, Jul 30, 2013.
  1. junglistluder
    junglistluder F1 Rookie
    Mar 23, 2007
    3,617
    VA
    Brendan
    #1 junglistluder, Jul 30, 2013
    I am replacing the steering rack in my 355 and decided to install new bellows on the replacement steering rack before it is installed. Well I realized that the Ferrari bellows are $150 each!! That's just ridiculous. So I took my old bellow up to my local auto parts store and they let me go through all the steering rack bellows to find a match. Well after looking at tons of rubber boots I finally found one that works perfect. It is for a Subaru but the dimensions are the exact same as the OEM boot, it even has the same number of ribs. The only differences are that the tie rod opening is a bit smaller on the subaru boot and there is a rubber gaitor on the rack end of the boot. The fitment is perfect and they only cost $20 each!!
    In the first pic, the Ferrari bellows are the 2 on the right. They are the same part just one is more stretched than the other. The bellow on the left is the Subaru one.
    In the second pic, you can see the difference between the tie rod openings. No issue here, it slips right on.
    The third picture shows the additional rubber gaitor on the rack end of the boot. The opening for the rack is the same and fits perfect, there is just this extra .25" flap that sticks up. This will not interfere with anything at all so I just left it, but you can trim this off with scissors if you want it to be flush.
    Conclusion: Save yourself $250 and buy these Subaru boots if you need to replace them on your steering rack. :)
    BRAND: Beck Arnley
    PART#: 1032696
    COST: ~$20/ea.
  2. plugzit
    plugzit F1 Veteran
    7,775
    Redondo Beach, CA
    Bruce Bogart
    Great find!!!!
    Post it on the parts interchange thread please, so I can find it when I get off my dead butt and do mine.
  3. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,892
    Richmond
    Pete
    Great find, I was going to take the same tactic when I got around to replacing mine (take an old one to the parts store and start going through boxes). Thanks for saving me the effort!
  4. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    Thanks for the post Brendan.
  5. Rob'Z
    Rob'Z Formula 3
    Mar 29, 2008
    1,024
    Tucson,AZ
    Robert
    Awesome info, now find one for the shift shaft bellows on the trans.....$83 is too much for such a small item. ;)
  6. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Yipi ki ya, Nice
  7. 355tsr
    355tsr Formula Junior
    Mar 9, 2010
    322
  8. Beetle
    Beetle Formula Junior
    Apr 10, 2013
    776
    What's the Subaru PtNo or what model Subaru did the bellow come from?? This info helps heaps when purchasing. Great alternative though great work
  9. 355tsr
    Mar 9, 2010
    322
    I looked it up 2000 outback
