F355 Steering Wheel Adapters | FerrariChat
Discussion in '348/355' started by 16v2911TT, Mar 23, 2017.
  1. 16v2911TT
    16v2911TT Karting Silver Subscribed
    Oct 4, 2013
    168
    LA
    Kinda of dumb question, I have an 1995 F355 with the stock airbag steering wheel. I'd like to install a 6-bolt non-airbag steering wheel. The two HE options from Ricambi are:
    SWA-355-02: for airbag cars
    SWA-355-01: for non-airbag cars
    My car has an airbag but I’m installing a non-airbag wheel, so I buy SWA-355-01, correct?
  2. INTMD8
    INTMD8 F1 Veteran Owner Silver Subscribed
    Jun 10, 2007
    6,776
    Lake Villa IL
    No, I believe you need this-
    https://www.ricambiamerica.com/sws-355b-f355-steering-wheel-spacer.html
    As I understand it the above would be for 6-bolt momo on an original airbag car.
    SWA-355-02 is for mounting an early OEM non-airbag 4bolt/small pattern wheel to an original airbag car
    SWA-355-01 is for mounting a 6-bolt momo to an original non-airbag car
  3. Dave rocks
    Dave rocks F1 World Champ BANNED
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    I'd suggest contacting Hill Engineering or Ricambi and getting clarification.
  4. DaisyCutter
    DaisyCutter Formula Junior
    Jul 15, 2014
    255
    Sweden
    Dayan
    Correct.
  5. 16v2911TT
    Oct 4, 2013
    168
    LA
    Thanks for the replies guys. I've reached out to HE as well.
  6. drbob101
    drbob101 F1 Rookie Owner Silver Subscribed
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    I am interested to see how Jim does with the O2 adaptor.
    I contacted hill about mounting my non air bag OEM wheel ( 4 holes) to my 97 car ( airbag) and they said they didn't have anything for that application.
    It sounds like the OP is using a non OEM replacement (6 bolt) which they should have.
  7. INTMD8
    Jun 10, 2007
    6,776
    Lake Villa IL
    Not sure what else large to small 4 bolt pattern would be for but I'll find out soon enough!
  8. Dave rocks
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    Jim - those 4 holes don't appear to be threaded holes.
    But, you could likely modify this if need be to make it work.
  9. INTMD8
    Jun 10, 2007
    6,776
    Lake Villa IL
    The counter bored outer holes aren't threaded, would use stock hex bolts.
    2nd set in, just in from the counter bored holes are threaded (for steering wheel).
    3rd set in are not threaded, reliefs for fasteners that bolt inner horn pad support to the steering wheel.
  10. Dave rocks
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    I thought those were the ones you were talking about - my mistake.
  11. INTMD8
    Jun 10, 2007
    6,776
    Lake Villa IL
    No you're right, those aren't threaded :D
  12. CANDREAM
    CANDREAM Canada
    Nov 13, 2009
    407
    Burlington, Ontario
    Sadi
    search for my thread ...might be what you are looking for
