F355 Steering wheel options | Page 8 | FerrariChat
Discussion in '348/355' started by CCWillF355, Jun 29, 2020.
Tags:
  1. ShineKen
    ShineKen Two Time F1 World Champ
    20,087
    Southern California
    Nostradamus
  2. outlaw_singer
    outlaw_singer Karting
    Aug 23, 2015
    164
    Thats what you wanted to know? I could have confirmed that without taking a pic too :D
    ShineKen likes this.
  3. ShineKen
    20,087
    Southern California
    Nostradamus
  4. ShineKen
    20,087
    Southern California
    Nostradamus
    In your opinion, do you think the 110mm diameter is sort of standardized on older the Ferraris and the only real difference is length? As in… these could possibly work on my 355??
  5. ShineKen
    20,087
    Southern California
    Nostradamus
    Good chance the shorter one is for an F50.
  6. ShineKen
    20,087
    Southern California
    Nostradamus
  7. ShineKen
    20,087
    Southern California
    Nostradamus
  8. outlaw_singer
    Aug 23, 2015
    164
    Well, thats what i was hoping to get figured out here as i myself cant tell for sure.
    I just had a quick look online and it seems the hub C3905 has the same mounting pattern on the bottom like the ones i have here.
    I have no clue about the interchangablility of steering hubs between the different ferrari models but it and F40 wheel/hub fits a 355, than that one will most likely fit your 355.
  9. ShineKen
    20,087
    Southern California
    Nostradamus
  10. ShineKen
    20,087
    Southern California
    Nostradamus
  11. ShineKen
    20,087
    Southern California
    Nostradamus
    #3905 is specifically for an F40 and measures 100mm tall. Close to the one you have at 95mm. Yours is probably specifically for another car, although it will probably work on a F40.
  12. ShineKen
    20,087
    Southern California
    Nostradamus
    @outlaw_singer Your 70mm tall one is for these applications:
    FERRARI 208 (GTB-GTS TURBO) 1980-1986
    FERRARI 308 (GTB-GTS) 1975-1985
    FERRARI 328 (GTB-GTS) 1985-1989
    FERRARI 365 (GTC/4-GTB/4-GT/BB) 1966-1970
    FERRARI 512 BB 1976-1984
    FERRARI GTO 1984-1985
    FERRARI MONDIAL (3,2-8) 1980-1993
  13. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    Ken,
    You are the one true repository for Ferrari parts and most likely your records are more exhaustive than the official Ferrari Parts Manuals. :)
    Barry
  14. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    I'm lucky to have an F355 Challenge where the Regulation Manual permits certain modifications which might differ from car to car. So when my car was being set up for me, I had this 1 centimeter spacer fabricated to mount my steering wheel with its quick-release hub...
    When Peter Sachs offered to autograph my car, I asked him to autograph the original momo wheel...
    I replaced that wheel with this momo Competition wheel...
    It's all original and permissible driver's-choice gear. :)
  15. ShineKen
    20,087
    Southern California
    Nostradamus
  16. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
  17. ShineKen
    20,087
    Southern California
    Nostradamus
  18. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,927
    Richmond
    Pete
    I'm working on another airbag wheel option - I've always liked the 550 wheel better than the 355/456 wheel and it turns out the '02-'07 Maserati's use what appears to be the same wheel, but around 1/3 the cost. I have one coming and if it looks good will order a 550 airbag (ouch) to complete it.
    Targatime likes this.
  19. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    14,180
    MO
    Omar
    The momo 3 spoke was indeed shared between the 550, 456M, and several other cars including Maserati and even some Hondas. However I am not sure if the rear spline matches between maseratis and Ferraris.
    I would first confirm that before buying an airbag. Also the airbag is likely cheaper from a 456M
  20. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,927
    Richmond
    Pete
    Yep - that's why I bought just the wheel. It was cheap enough to not be a big deal if it doesn't work. However, it's just got the 4 bolts that attach to the existing hub, though, no splines. This is like the one I bought: https://www.ebay.com/itm/116002932379?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=8V3HiRzzQ4W&sssrc=2047675&ssuid=WKO0AFnNS7S&widget_ver=artemis&media=COPY
  21. Auraraptor
    Sep 25, 2002
    14,180
    MO
    Omar
    As long as you have your OEM steering wheel you can swap the rear spine mount without much issue. I am pretty sure they match as both were from momo originally.
    PS consider restoring if so inclined.... I had a spare 575 steering wheel refinished and still am happy with the result: https://ferrarichat.com/forum/threads/steering-wheel-refresh.660172/
  22. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,927
    Richmond
    Pete
    That looks really nice, I'll see if I can procure an airbag and then may do just that.
    Auraraptor likes this.
  23. outlaw_singer
    Aug 23, 2015
    164
    Thanks for the info Ken. I must add, while most of this could be accurate, it's highly unlikely for a hub to fit different models over such a long timespan. In this case, i'm 99% sure at least the 365 (1966-1970) will need a different hub.
  24. lanab
    lanab Formula Junior
    Feb 21, 2016
    527
    Stockholm, Sweden
    You have a picture of the 550 wheel installed?
    I found a picture of a 550 wheel but in beige, don't know, it looks a bit clumsy and big for the interior.
