News
F355 Transmission Resistance
Discussion in 'Technical Q&A' started by RAC911, Feb 10, 2019 at 7:00 PM.
  1. RAC911
    RAC911 Karting
    72
    Arizona
    Ralph Cacace
    I have a 1996 F355 Sypder with 6 speed manual. When first staring the car, the transmission resists going into any gear from 1st gear. With cold weather, it takes a long time to be able to put the transmission in the gears. That would imply that the gear oil is the wrong type. Any suggestions?
  2. Qavion
    Qavion Formula 3
    Feb 20, 2015
    1,596
    Ian Riddell
    It could still be an adjustment problem. I've had a problem where it was harder to select some gears when the car warmed up. You need someone sitting in the car selecting all gears and have another person tweaking the settings.
    My oil was new and recommended (Redline 75W90NS with a few capfuls of Redline friction modifier). Don't use Redline "ShockProof". The manufacturer doesn't recommend it for the F355.
    Of course, there could be other problems. Sagging engine mounts have been known to cause problems with gearchanges.
  3. mrknowitallf40
    mrknowitallf40 Formula Junior
    Feb 20, 2005
    292
    Switching back to the oem fill would be a good first step.
  4. yelcab
    yelcab F1 Veteran
    Nov 29, 2001
    8,597
    San Carlos, CA
    Mitchell Le
    Change oil first, then mess with the adjustment at the bottom of the engine after.
  5. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    6,180
    DO the oil change first,
    do the adjustment second,
    If these don't fix the problem, you could be looking at synchronizers in the tranny.
  6. INTMD8
    INTMD8 F1 Rookie
    Silver Subscribed Owner
    Jun 10, 2007
    4,981
    Lake Villa IL
    James Moran
    Just pretend it’s an F1 and hulk smash it into 2nd, it’ll go :D
  7. tbakowsky
    tbakowsky F1 World Champ
    Professional Ferrari Technician Consultant
    Sep 18, 2002
    13,924
    The Cold North
    Tom
    First item to check are the engine mounts.
    Bad mounts can cause a rather troublesome shift. If the fluid in the gearbox is the correct spec, it will not be your issue. After the mounts are replaced, reset the shift adjustment as needed. If you are not familure with how to do this, pay to have it done. A miss adjusted shifter can cause a few expensive issues.
  8. taz355
    taz355 F1 Rookie
    Feb 18, 2008
    4,481
    Indio Ca/ Alberta
    Grant
    And its no fun to drive
