F355 upper plenum | FerrariChat
F355 upper plenum
Discussion in '348/355' started by jeffdavison, Feb 1, 2020.
  1. jeffdavison
    jeffdavison F1 Rookie
    Jul 29, 2002
    2,544
    Suwanee Georgia
    Jeffrey Davison
    It doesn't appear to be that difficult. Has anyone removed their upper plenums with the engine in place? I'd like to clean mine up and refinish on the bench rather mounted on the engine in situ). Looks just like the removal of the allen screws holding the top on from the underside. (of course after removing the intake tubing). Looks like the only potential problem could be access and the possibility of dropping them as they come of. Nimble finger seem to be a requirement.
  2. fboutlaw
    fboutlaw Formula Junior
    Dec 3, 2014
    261
    Woodside, CA
    This is a normal procedure.
    Remove the plastic beauty cover for the coolant and power steering.
    Disconnect 2 vacuum lines (small one closest to the cabin, and one near the rear).
    Disconnect the oil breather lines.
    Loosen the metal rings until they are on the verge of separation on the bottom of the plenums.
    You should then be able to wiggle off the plenums. If they're stuck, you need to loosen the metal rings further.
    jeffdavison and Qavion like this.
  3. jeffdavison
    Jul 29, 2002
    2,544
    Suwanee Georgia
    Jeffrey Davison
  4. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,632
    Elliott Caras
    It’s easy to remove the plenums as a unit but a PITA to reinstall them. Your asking if you can take the plenum top halves off, I have seen it done, and yes you’d need to be super careful with the bolts.
    It’s actually quite easy to freshen the Plenums whilst it’s in the car. If you do split the Plenums you might want to get the gaskets for reinstall.
    Illyria and Qavion like this.
  5. jeffdavison
    Jul 29, 2002
    2,544
    Suwanee Georgia
    Jeffrey Davison
    Actually I want to paint or powder coat them... just a wee bit difficult to do in the car....... and new gaskets will be mandatory.
  6. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Remove them as an assembly, rebuild and pressure test them.
    Here is a 8k mile 355 with new gaskets installed was not good enough. Took some tweaking to correct. 20+ year old plastic warps.
    Test your intake system and retest. Have not seen many that did not leak
    jeffdavison likes this.
  7. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    I hate this job.
    WATSON and MAD828 like this.
  8. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,027
    NE FL
    Ken
    You will need new gaskets. they will break. Get a back brace lol
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    They are easy to get off as a unit and hard to get back on. I take the clamps and spacers right off.
    Personally I would clean really good and paint new lines like lots of us have in the car.
    Then when you do your next engine out powder coat them.
    This is def not impossible, just get used to dropping the parts.
    I would not split them as I felt the allens were harder to get at then the clamps and spacers
    MAD828 likes this.
  10. jeffdavison
    Jul 29, 2002
    2,544
    Suwanee Georgia
    Jeffrey Davison
    Next engine out will be over 5 years from now as it was just done last June.....
  11. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Then I would still take them off as a unit.
    It depends on how the engine out guy positioned the clamping screws. I set mine so that I can get at them not sure how yours are turned
