F355 valve hit piston | FerrariChat
Discussion in '348/355' started by Buckets, Jun 28, 2024.
  1. Buckets
    Buckets Karting
    Sep 9, 2019
    130
    Seattle, United States
    Nick Papagiorgio
    Noticed a nice mark on my piston. The engine still runs but has no compression on the #3 cylinder. Am I the first person to achieve this feat?
    I'm going to put a new engine in, but I was just curious why a valve would hit a piston. Maybe a stuck lifter or valve spring, or dropped valve seat?
  2. Buckets
    Buckets Karting
    Sep 9, 2019
    130
    Nick Papagiorgio
    It might be a burnt valve I'm looking at. The engine has a lot of carbon as well.
  3. carnutdallas
    carnutdallas Formula 3
    1,970
    Dallas Burbs
    Rob
    Rebuild the engine. Don’t replace it. Really, just a head job. Don’t buy an unknown as well as lose the originality. Just my 2 cents. Cheers.
    PaulK, tres55, Buckets and 2 others like this.
  4. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,721
    The only way to put a "new" engine in it is to completely rebuild the current engine.
    And I don't care about originality--I do care about an engine that runs properly.
    Buckets and Rifledriver like this.
  5. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,449
    Los Angeles
    Can you post more images. That doesn't really look like a witness mark. Valves hit pistons on an angle because they aren't perpendicular to the piston top. They leave a crescent moon type impression, or an eyebrow, not a perfect circle like in your pic.
  6. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    756
    Vermont
    john truskowski
    Yes, I wouldn't go running down a replacement engine just yet. I would continue to diagnose why you don't have any compression and see where that leads you. Heavy carbon on those valves could give you this problem and it would be a shame to replace the entire engine for a carbon issue.
    Buckets likes this.
  7. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    For this car, I would always stick with the devil I know. Rebuild the head. You may need new liner and piston (1 set).
    Buckets likes this.
  8. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,217
    CT
    John Kreskovsky
    You are going to have to drop the engine. Once that's done, pull the head and see what the issue is. If needed do a valve job, clean the carbon, and then decide if you want to do the other head as well.
    Buckets likes this.
  9. Buckets
    Buckets Karting
    Sep 9, 2019
    130
    Nick Papagiorgio
    Thanks for the comments and guidance, everyone.
    My goal is also an engine that runs well. I was thinking about swapping in a spare motor to drive the car sooner. Then I could take my time rebuilding the original engine.
    You inspired me to get a better scope so I'll snap some better pics soon.
    Agreed, and I would be very happy if it's just carbon causing my problem.
    Definitely. I'm at 50k miles so it's probably worth inspecting both heads if I'm going to do one side. The motor needs a belt service at a minimum so I will be dropping it out soon.
  10. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,449
    Los Angeles
    Have you done a leakdown? Then you'd know if the compression loss was from intake/exhaust/rings
  11. Buckets
    Buckets Karting
    Sep 9, 2019
    130
    Nick Papagiorgio
  12. carnutdallas
    1,970
    Dallas Burbs
    Rob
    Bummer
  13. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,449
    Los Angeles
    That's legit. Now the question is, what caused the burned valve. (If I'm seeing the pic correctly, you have a chunk of valve missing -- or is that just carbon?)
    NYC Fred and Buckets like this.
  14. m.stojanovic
    m.stojanovic F1 Rookie
    3,217
    Serbia - Niš
    Miroljub Stojanovic
    To me, it looks like the valve hit the piston (impact mark seen on the pictures in posts #11 and #1) which caused part of the valve to brake-off. It does not look like a burned-off portion.
    montegoblue, yelcab and Buckets like this.
  15. Buckets
    Buckets Karting
    Sep 9, 2019
    130
    Nick Papagiorgio
    Correct, it's a chunk gone from the exhaust valve. I'm not sure if it broke off or eroded away. You can see a burn pattern in the port next to the hole, and I'm not sure where the any valve pieces went. They aren't in the exhaust.
  16. Timmo
    Timmo Formula Junior
    Aug 26, 2017
    680
    Continental Europe
    Those are seriously dirty exhaust valves. How many miles on the engine?
  17. Skippr1999
    Skippr1999 F1 Rookie
    4,506
    He said 50k
  18. johnk...
    Jun 11, 2004
    11,217
    CT
    John Kreskovsky
    The car is a '95, 2.7. They tend to run rich.
    Buckets likes this.
  19. Buckets
    Buckets Karting
    Sep 9, 2019
    130
    Nick Papagiorgio
    Yea it has 50k but I think the oil seal and/or guide is just blown out on this cylinder. The other exhaust ports at least are not covered in oil like this one.
    Even with "running rich" all of the intake ports and valves look pristine. No carbon at all on those.
  20. Timmo
    Aug 26, 2017
    680
    Continental Europe
    My late '95 also has 50k miles but the exhaust valves didn't look anywhere as dirty as that when I fitted Tubi headers. I would agree that oil must have made its way down there.
  21. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,751
    Lake Villa IL
    This based on what?
  22. johnk...
    Jun 11, 2004
    11,217
    CT
    John Kreskovsky
    Should have been more specific. My 2.7 tends to run rich. Based on what the plugs look like.
  23. yelcab
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    I have seen this multiple times on 355. The valve guide wears out, allows engine oil to slip past the stem causing thick deposits on the back side of the valve. The valve is no longer able to dissipate its heat from combustion and the valve burns off at the point of most heat retained. You need a valve job, all new guides, and replacement of all valves in that cylinder, and any other questionable valves. A proper repair includes replacement of the affected liner.
    ShineKen and Buckets like this.
  24. Buckets
    Buckets Karting
    Sep 9, 2019
    130
    Nick Papagiorgio
    #24 Buckets, Sep 9, 2024
    I'll have all the guides checked. I have paperwork that they were replaced back in '06 and they appear to be steel but that doesn't mean they aren't worn.
    The crack in my valve seems to be pointing toward the exhaust port (similar to your photo) so I wonder if it was an exhaust leak that contributed to the burning.
  25. redwedge
    redwedge Formula Junior
    Sep 30, 2012
    462
    London
    Steve C
    I had similar happen on my car, although the valve guides (including the one for the burnt valve) were fine. In my case it was caused many thousands of miles ago by a cracked exhaust manifold, so you may well be correct about an exhaust leak. The valve operated in its weakened state for many years before eventually letting go on the way to Le Mans, a long way from home! 2x new exhaust valves and a new liner later, all was good. See discussion here https://www.ferrarichat.com/forum/threads/no-compression-on-cylinder-2.679644/
    Buckets likes this.
