F355 - What type of headers should i go for? | Page 3 | FerrariChat
Discussion in '348/355' started by Freddan, Aug 25, 2014.
  1. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,027
    PA
    Kevin
    Daniel,
    Can you provide more details about these? Thickness, type of steel, etc.?
    I cut open a 1998 OEM header a few weeks ago and measured the inner tubes. Generally I was seeing 1.0-1.3mm thick which corresponds to 18 gauge metal. It would be nice to get more data as this seems to be a nice option...
  2. Ricambi America
    Sponsor Owner
    #52 Ricambi America, Aug 27, 2014
    304 stainless, 1.5mm.
    Here is a picture of a finished header:
    (Please note, each one will be different, depending on the ability to get the original heat shields cleanly cut with the least amount of "lost" material)
  3. Shootfighter65
    Shootfighter65 Formula 3
    May 13, 2014
    1,372
    Charleston SC
    Randy..alluneedtokno
    #53 Shootfighter65, Aug 27, 2014
  4. Freddan
    Freddan Formula 3
    2,450
    Vansbro (Sweden)
    Fredrik
    shootfighter65:
    How much for a set?
  5. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    Depends if you want the air rail... around $3200 Thats a competitive price and also take into account that they are put back into the factory clam shell ..if you go with fabspeed or others you should run header blankets these its not necessary.
  6. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    See Jim's thread I posted above - look up a few posts ;)
  7. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    bare headers I think start around $2400
  8. Freddan
    Freddan Formula 3
    2,450
    Vansbro (Sweden)
    Fredrik
    Ah! Thanks Dave
    Better torque than hp for me so 4-2-1 for sure. (Swedish road does not allow high speed driving)
  9. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,372
    Southern New Jersey Shore
    Phil
    Can someone explain how, or why, 4-2-1 gives more torque but 4-1 gives more HP?
    In looking at the relatively short distance between the pipes and the collectors, I'm trying to understand why there is a difference. Is it a change in back-pressure from one design to the other?
  10. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    Sorry I can't give you the technical explanation, but it probably has to do with pulses "pulling" the exhaust out. One of my old race engine builders told me: "Horsepower sells motors, but torque wins races".
  11. ShineKen
    ShineKen Two Time F1 World Champ
    20,189
    Southern California
    Nostradamus
    My personal vote would be for the 321 stainless steel headers by Stainless Headers. None of these other manufacturers are making them in 321, but are charging a hefty price tag for them (ex. tubi). 321 stainless steel is basically 304 stainless steel with some titanium in it. It is generally lighter and more durable.
    Fabspeed headers are 4-1 and 40 gauge stainless steel. Thick enough to last a lifetime, hence the lifetime warranty, but heavier than a 16 guage 321 stainless steel header.
    If the price is within the same ball park, I'd rather go with the 321 4-2-1 design. Keep the torque the same. Retain the F1 sound and lighten up the rear at the same time.
  12. ShineKen
    20,189
    Southern California
    Nostradamus
    I'm also not a fan of the factory heat shields. In the case that something is wrong, it is impossible to see what is going on unless the headers and shields are removed.
    I had contemplated having a local shop build me a set in pretty much the same specs Stainless Headers has them built. However, I wanted them ceramic coated only on the inside and very thoroughly. I figured I'd send them to Swain tech (White Lightning coating) in pieces, so they could be coated thoroughly on the inside. Swain Tech mentions at least .015" thick to be of any effective long-term insulating value.
    White Lightning Exhaust Coatings | Swain Tech Coatings | Industrial Coatings | High Performance Racing Coatings
    I am speculating and hoping coating only the inside will be effective enough to reduce adverse heat in the engine bay while protecting components such as the alternator in Inconel. This should allow the header to effectively breathe as opposed to being insulated by shields or a top layer ceramic coat. If it doesn't work, I will probably looking into a blanket. Fabspeed offers pretty nice looking ones.
  13. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,995
    Northeast U.S.
    Jim
    #64 jimmym, Aug 31, 2014
    Ken, Hytech which is located in California builds very nice headers. They would build them in 321 s/s. They built headers for Ernie's 348 in 321 s/s. The headers looked very nice.
    Stainless Headers would probably prefer to build them without the shields as it is more work for them. The cost would also be ~ $650 cheaper. But keeping the OEM look as well as protecting the engine bay components was important to me that is why I retained the OEM shields.
    I know some owners have coated their headers and have been happy with it. I am just not sure how evenly the coating could be applied to the inner tubing? How long it will last?
    What happens if it starts coming off and if it will end up back in the motor? I don't believe anyone had boroscoped their headers prior to installation and has taken them off periodically to see how well the coating is holding up over time.
    There was a thread about header coatings awhile back.
