F355 whistle/whine | FerrariChat
F355 whistle/whine
Discussion in '348/355' started by Williamhh, Jul 16, 2015.
  1. Williamhh
    Williamhh Rookie
    Mar 31, 2015
    17
    Hi all
    I have recently developed a whine which is directly related to engine speed and not transmission speed. It is not consistently there but is generally speaking not present on cold start and then on and off throughout warm usage.
    I have therefore ruled out the secondary air pump sound on cold start which most people seem to report.
    Closest thing I could compare it to would be supercharger whine.
    Any guidance to prepare me for the worst would be much appreciated!
    Will
  2. jochem00
    jochem00 Formula Junior
    Jun 19, 2014
    344
    Netherlands
    waterpump bearing
    or
    aircon pump
  3. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    There's an alternator and power steering pump to consider too. Is you power steering reservoir full?
  4. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,728
    The bearing at the back of the pumpkin can also make such a noise--it runs at engine speed.
  5. Rice-Racer
    Rice-Racer Formula Junior
    Jan 10, 2015
    252
    Maybe it's the wife whining as you buy more parts on your credit card? Kidding, had to say it!
    Is it more noticed driving very slow and try turning wheels back and forth, just a test on steering pump? Flick on AC and see if it comes or goes?
  6. f355spider
    f355spider F1 World Champ
    18,044
    #6 f355spider, Jul 17, 2015
    I had more of a shrill screeching noise. Started out as a faint scraping noise, got louder over time. It was intermittent. Went on for about three months of driving, then after about 600 miles, the throwout bearing housing cracked and let go....with all the hydraulic fluid draining out, and no more clutch action.
  7. Loser
    Loser Formula Junior
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    Maybe the alternator belt tensioner bearing.
    Sent from my SM-G900V using Tapatalk
  8. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    All of the above suggestions plus don't forget the AC compressor. Mine was bad and a rebuild did the trick. Get a 3 foot section of 1/2 " tubing and hold one end at your ear and then go exploring with the other end to isolate the sound. You will be surprised what you may find. Good luck.
