F355GTS top adjustment | FerrariChat
Discussion in 'Technical Q&A' started by k wright, May 4, 2004.
  1. k wright
    k wright F1 Rookie
    Feb 4, 2004
    2,544
    North East TN
    Kent Wright
    I would appreciate help with adjusting the top on my car. It rattles at the front attachment points. After looking it over it appears that the only adjustment available is at the rear of the panel.
    Thanks,
    ken
  2. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    Check for wear in the handle itself, if it's okay then there are shims that are under the striker plate that can be removed or added accordingly. There is also a shim under the handle itself that can be removed. The part number for the shim that fits under the striker plate is #63238700
    Bear in mind that you can either raise or lower the roof by adding or removing the shims, depending on what you need to achieve.
    Check that the handles are secured tightly and that there isn't excessive wear on the rear pins.
    MW
  3. k wright
    k wright F1 Rookie
    Feb 4, 2004
    2,544
    North East TN
    Kent Wright
    I greatly appreciate the help. The top is now rattle free. On to the dash!
    ken
