F360 Battery Charger RecommendationNew F360 | FerrariChat
Discussion in '360/430' started by greggyll, Feb 14, 2011.
  1. greggyll
    greggyll Rookie
    Nov 22, 2010
    10
    Just bought a 2004 standard transmission F360!
    I need to buy a trickle charger and everyone seems to recommend the Schumacher brand.
    What model number do you guys like?
    How do you mount it/fasten the connectors?
    Thanks in advance!
    Greg
  2. vrsurgeon
    vrsurgeon F1 World Champ
    16,543
    Charleston, SC
    Curt
    I bought a CTEK 800 and mounted the plug connector to the battery in the event I needed to turn off the ground switch to the chassis.. I understand some owners mount their plug to the positive lead behind the drivers seat.
  3. RobD
    RobD Formula 3
    Nov 10, 2003
    1,182
    #3 RobD, Feb 14, 2011
    Congrats on the 360!
    I always recommend the Deltran Battery Tender Plus. It's a tender, not a trickle charger which can overcharge the battery. The Deltran is reasonably priced and works well.
    Do a search and you'll find good threads on the subject.
  4. sk8rpatty
    sk8rpatty Formula Junior
    Dec 13, 2010
    316
    So Cal
    Patty H.
    I use the same one. I connected the plug behind the seat, this way I just crack the window, run the cable in and connect at the plug.
  5. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    Deltran all the way. Inexpensive and very reliable.
  6. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,166
    Wash DC area
    Robert
    Ctek, never an issue.
  7. ttdang123
    ttdang123 Formula Junior
    Nov 28, 2009
    706
    North San Diego CA
    Tung
    CTEK 3300 with the permanent dongle at the passenger foot-well.
  8. Markjayw
    Markjayw Karting
    160
    Kennewick, Wa.
    Mark
    CTEK,
    Just get the cigarrette lighter adapter, my car sat for 3 months this winter, started up perfect. No need to do any kind of pre-wiring.
  9. lukek
    lukek Formula 3
    May 2, 2003
    2,085
    San Francisco
    LK
    same here, attached the lead from the trickle charger to the side post of the battery (under passenger floorboard)
    I found one online, similar to this, gasp !!!!....lambo-branded one:
    http://cgi.ebay.com/ebaymotors/FERRARI-MAINTENANCE-BATTERY-CHARGER-TENDER-3300-_W0QQcmdZViewItemQQhashZitem5196764156QQitemZ350416683350QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_2551wt_800
    The "permanent dongle" gets, ahem..... tucked under the floormat
  10. Rifledriver
    37,106
  11. Skidkid
    Skidkid F1 Veteran
    9,539
    Campbell, CA
    John Zornes
    Forget the footwell. Go to the terminals behind the drivers seat. Much less intrusive
  12. RobD
    RobD Formula 3
    Nov 10, 2003
    1,182
  13. Markjayw
    Markjayw Karting
    160
    Kennewick, Wa.
    Mark
    You guys are doing more work than necessary. All you need to do is get a CTEK charger, and purchase the optional cigarette lighter adapter, then when you want to charge the car you just plug it into your lighter adapter. No need to run anything from the battery directly.
  14. Skidkid
    Skidkid F1 Veteran
    9,539
    Campbell, CA
    John Zornes
    Looked interesting until they had a list of what it does then said "I'm not done yet ..." If it weren't for the source posting the link I would simply write them off as a midnight infomercial with minimal value.
  15. maxer
    maxer Rookie
    Oct 19, 2010
    23
    Colorado
    Skip Miller
    On my CS the lighter shuts off with ignition so that won't work at least in the CS.
    I went straight to connection behind drivers seat where I installed triple cig plug so any time I want unswitched 12 volt access I have it. Put my older Porsche cig lighter chrger on timer for 3 hours per day. Works PERFECT!
    Maxer
  16. sk8rpatty
    Dec 13, 2010
    316
    So Cal
    Patty H.
    ...and you can leave your "permanent dongle" back there. Just as easy as the lighter once it's hooked up initially.
  17. fc2
    fc2 F1 Veteran
    Nov 2, 2006
    5,263
    Silicon Valley Ca.
    Frank C.
    +1 My experience as well.
  18. Rifledriver
    37,106
    #18 Rifledriver, Feb 15, 2011
    It is the best product out there.
    Founder is a local guy and a car/motorcycle collector.
    For all you guys going to the cigarette lighter......bad idea.
    I have repaired some seriously burned up wiring harnesses because of that.
  19. Skidkid
    Skidkid F1 Veteran
    9,539
    Campbell, CA
    John Zornes
    Thank you Brian. I will get one and replace my Deltran.
  20. Skipper
    Skipper Formula Junior
    Sep 24, 2006
    451
    Frank Drebin
    ok so which is the best tender?
  21. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Best tender? Drive it - she's got a built in tender and it's much more fun!
    Seriously!
  22. jznd
    jznd Formula Junior
    Oct 26, 2008
    373
    Hong Kong
    My cars are frequently running low on juice (just enough not to be able to turn the engine over) because I can go for a couple weeks between driving them. I always turn off the power, but I guess there's still a residual current drain even with the battery cutoff switch in the off position. (Anyone know if this is true?)
    Unfortunately, I have no wall socket near my parking space in my apartment building so can't use the tender that came with the 430. The 360 and 550 don't have this feature anyway. To make things worse, even jump starting is not easy because the parking space is tight.
    I'm thinking about buying a regular lead acid battery, keeping it topped up with a charger/tender in the house, and using that battery to "charge up" a car whose battery has run down by connecting it to the battery for, say 10 minutes. If the battery in the car is too depleted for that to work, I can use the extra battery to jump start (always a last resort). Does this make sense? Is there an easier work-around?
    (I've seen some products with a built in battery but haven't seen one here in Hong Kong. No Autozone or PepBoys here. http://www.amazon.com/Schumacher-IP-125-Instant-Starter-Battery/dp/B000TD6S9U/ref=sr_1_21?s=automotive&ie=UTF8&qid=1300264463&sr=1-21)
  23. F1.360.LOVER
    F1.360.LOVER Formula Junior
    Dec 12, 2009
    476
    Central Florida
    Nate
    First of all, I would not jump start your car. I believe the "save a battery charger" can be used without being plugged into an outlet.
  24. concours
    concours Karting
    Jan 10, 2008
    120
    Palos Verdes, Ca
    Richard
    One of my favorite notes from the 360 Owners Manual, page 5.20: [English section]
    "Do not use devices to be connected to the cigar lighter" Fair warning huh!
  25. jznd
    jznd Formula Junior
    Oct 26, 2008
    373
    Hong Kong
    A while ago I was looking at a 360; service receipts included a hefty bill for replacement of wiring damaged by a plug-it-into-the-cigarette-lighter battery tenders. To rephrase what my slightly deranged uncle once told me (when I was 16), "if it wasn't designed for it, don't plug it in".
