F360 Blower Regular 64280200 | FerrariChat
Discussion in 'Technical Q&A' started by mxbennett, Jun 21, 2021.
  1. mxbennett
    mxbennett Rookie
    Aug 27, 2010
    13
    I have a non functional blower regulator 64280200 from an F360. Can't seem to find a replacement.
    Is there someone who rebuilds/reconditions them?
  2. virendra
    virendra Formula Junior
    Jun 14, 2008
    251
    Hong Kong
    virendra anand
  3. virendra
    Jun 14, 2008
    251
    Hong Kong
    virendra anand
    I probably have all parts for the 360
  4. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,290
    Ian Riddell
  5. mxbennett
    mxbennett Rookie
    Aug 27, 2010
    13
    Thanks Qavion
    I was able to order parts, the power transistors, and replace them in the regulator. Took about an hour to open the unit, test the old ones to verify they were bad and replace them. System works properly again.
    Qavion likes this.
  6. EastMemphis
    EastMemphis Formula 3 Owner Silver Subscribed
    May 25, 2019
    1,853
    Memphis, TN
    You should document exactly what you did and where you got the parts so others in a similar spot can benefit from your experience. Thanks!
  7. Qavion
    Feb 20, 2015
    14,290
    Ian Riddell
    Great to hear, although fitting updated transistors might have been better in the long run.
    What was the main impediment to opening up the case? Did you have to cut or drill something?
  8. Qavion
    Feb 20, 2015
    14,290
    Ian Riddell
    Sorry, misread your answer. After re-reading, I see the whole process took only an hour.
  9. Madmag
    Madmag Rookie
    Aug 5, 2022
    35
    Oscar franjul
    What problem the car present when the blower regulator stop working ?
  10. eric355
    eric355 Formula 3 Silver Subscribed
    Nov 30, 2005
    1,225
    Toulouse (France)
    Eric DECOUX
    Could be blower continuously ON at full speed or no blower at all depending on transistors failure mode.
    Had to repair one recently from a 430.
    Qavion likes this.
  11. hessank
    hessank Formula 3 Silver Subscribed
    Aug 8, 2005
    1,924
    Canada, Florida
    Fred
    Don't you hate it when someone comes here looking for a solution from the collective,
    solves the problem, keeps the solution secret and then disappears until he/she needs help again.
    Rant over
    EastMemphis and flash32 like this.
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,931
    Central NJ
    Dominick
    Drives me nuts :)
    hessank likes this.
