F360 engine head: gasket change + water leak? Low pressure in cylinders | FerrariChat
Discussion in '360/430' started by mowater, Dec 13, 2011.
  1. mowater
    mowater Formula Junior
    May 24, 2004
    362
    Okay gentlemen allow me first to announce that I am not mechanically, physically, inclined. My knowledge is mostly theoretical, based on what I read online, talk about with friends, and learn from my mechanics.
    I bought my F360 with my mind set on completing a major service no matter what, and have negotiated that in the price. I want the car to run on my clock.
    The mechanic has told me that there is a leakage in the engine head from the gasket. Water trickled down into the valves (is this correct? or accurate?), he claims, and he recommended that I perform an engine out to change the engine head gaskets, grind (I think this is the English term for what he described) the valves, and clean.
    This is after he has suspected initially that it could be spark plugs or ignition coils. Which he says it is not, by testing.
    His diagnosis is that this has happened because the car has been sitting and not really driven for an extended period of time, something like six months.
    He says that there is 'low pressure' in two cylinders.
    He has also went to advize that I do not drive the car so I do not hurt the connecting rods.
    Advice which to be honest was not convincing to me, and I have driven the car perhaps 150-200km yet and to be honest I have taken the RPM up to the 4-5 range on occassion, and to 7-8 a few times.
    I'm sorry but I really don't 'feel' anything. It's not perfect, as I describe below.
    My thoughts? Since I am already set on a major, why not take the engine out instead of performing it from the "window" behind the seats. Take the engine out, replace the engine head gaskets regardless, and clean the whole thing up.
    Am I feeling anything personally when driving the car?
    Nothing serious at all, no lights by the way, EXCEPT that I do hear a .. hmm .. small backfiring sound, like a pop, or a tiny 'explosion' (for lack of a better term) when I let my foot off the gas - SOMETIMES.
    Bear in mind that the car has a Tubi muffler, just in case this can have anything to do with this sound.
    When the trunk lid is open, yes, you can see that the engine connection to the air boxes is not static. It does shake.
    But, personally, am I wrong to believe that such could be the case due to the need of a major anyway?
    New belts, new spark plugs? Or is that irrelevant?
    Basically what I am feeling in terms of symptoms:
    1. AUDIO: A small pop sound, like a tiny backfire, SOMETIMES, when I let my foot off the accelerator pedal.
    2. VISUAL: I can see the engine connection shake and is not running smooth. Something in the ignition/combustion could be toned.
    3. SENSE: At idle, inside the car, yup, I can feel the car sometimes not being static. I can feel the engine behind me not being absolutely 100% still. Perhaps a 10% shake is sensed.
    Why am I asking all this when I know I am going to perform the engine out?
    1. I want to know what you guys recommend I order for safe measure since I am removing the engine cover and exposing the head.
    Gaskets, and ... ?
    2. I want to UNDERSTAND my motor. :)
    3. I hope this can be helpful to prospective and current owners.
    I also wish to know if anyone has or has had any of those symptoms, and what the diagnosis was, and how they have overcome it.
    Thanks in advance.
  2. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,760
    US of A
    Michael
    Well...
    If during your mechanics testing he has discovered two cylinders that have reduced compression numbers then he may have found something. He would have discovered that by performing a compression test. Now at that point he should do a "leak down" test that will give him another indication and much better pin-point the issues (if any) with those cylinders. It does that by sensing if you have compression escaping from either the valves, or past the piston rings. That would be what I would ask him to verify.
    Now to your questions:
    1. AUDIO: A small pop sound, like a tiny backfire, SOMETIMES, when I let my foot off the accelerator pedal. (pretty normal by sports car standards)
    2. VISUAL: I can see the engine connection shake and is not running smooth. Something in the ignition/combustion could be toned. (Without seeing this I would guess that either its fine & minor, or the two effected cylinders are contributing to the shake).
    3. SENSE: At idle, inside the car, yup, I can feel the car sometimes not being static. I can feel the engine behind me not being absolutely 100% still. Perhaps a 10% shake is sensed. (again, it could be normal, or you could be feeling the two down cylinders).
    1. I want to know what you guys recommend I order for safe measure since I am removing the engine cover and exposing the head. Gaskets, and ... ? (during a major you do not expose the head gaskets. Please understand that to expose the head gaskets is a huge undertaking. Cars go their whole lives without ever exposing their head gaskets).
    2. I want to UNDERSTAND my motor. (that could take a lot of teaching as I have done this for 30 years and learn new things daily).
    Thanks in advance.
  3. mowater
    May 24, 2004
    362
    #3 mowater, Dec 13, 2011
    Got it. Thank you sir!
    Yes, but this is recurring. I drive many sports cars, albeit the F360 is the only one with an aftermarket exhaust.
    Can the Tubi muffler itself be the cause of this? And not the combustion inside the engine?
    Just had a thought: This can be caused also by the engine mounts, correct?
    I did not check them by the way.
    I did know and understand indeed that during a major service for the F360 the head gasket is NOT replaced. :)
    However, can the gasket go bad from lack of use? If so, could it cause water leaking in and causing the compression to be low?
    ADDITIONAL question: if indeed there are two cylinders with low pressure, wouldn't the computers detect that and send me a CEL?
    Also, from your experience, and the readers' as well, do you think that performing a major service MIGHT take care of those symptoms? Especially since I have read that the timing belts can cause this as well, due to valve timing?
    I ask because now the way I see it is:
    a) Perform major service, the parts being those in the Kit from Ricambi, while engine is in place and access through the designated window behind the seats.
    b) Engine out. Perform major service. Change head gaskets and replace if necessary valves on those two cylinders. Clean everything as it is a 12 year old car but with only 44,000km
    PS: I realize this is all based on what a Leak Down Test will provide. However, it is a LONG story with the workshops here that work on Fcars and the point is that I want to UNDERSTAND what it is that I can/should do and in what order.
    Thank you for the guidance. It has been of IMMENSE HELP. :)
  4. m.roberts
    m.roberts Formula Junior
    Nov 2, 2009
    907
    My 430 acted up recently. It was intermittent at first, then things got more extreme.
    Had cel lights several times, a few backfires, some shaking, loss of power at times, etc
    Turned out to be cracked headers. I would check this before pulling your engine!
  5. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,837
    What year is your 360?
    How long have you owned the car?
  6. mowater
    May 24, 2004
    362
    Thank you for sharing!
    I will also check the whole air flow in/out!
    2000, and I have owned it for 3 days! :)
    All this diagnosis was done during the PPI. NOTE: Car was tested without an SD or any computer tool.
    I did not take the mechanic's word to heart, and drove the car because I was not convinced that it is indrivable.
    I wish to understand if these symptoms can be due to lack of use + need of a major service being due.
    That is because I need to decide whether I take the engine out: or settle for a major sevice through the window and see what results it yields.
  7. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Hi Mowater,
    Taking the head off to replace the gasket is a fair bit of work to do. You mentioned loss of coolant? (water trickles down to the valves). Have you measured the rate of loss? I would suggest filling the expansion tank to say 5cm below the neck of the filler cap and taking the car through a few heat cycles and drives and then re-measure to see if there is in fact a loss. Suggest you don't fill any higher than 5cm as otherwise your loss could be to the overflow pipe and you'll think you have a loss when probably you don't.
    Do you know just how low the compression is? A fit car will have a nice tight bunching of numbers for all cylinders. Often people get readings in the range of 160 +/- 10 psi from motors that feel perfectly fit and fine. I understand that a really good result is closer to 200 psi with no more than a 5% spread. The numbers often seem to vary but it's important that there be a good tight bunch of numbers.
    If you do have bad compression the next step is often to do a leakdown test which measures the cylinder's ability to hold pressure over a given period of time. This test can help identify if the problem relates to the piston rings or the valves or other. This test might also show signs of coolant being forced out of the head or air into the coolant system, both of which would confirm problem with gasket.
    If you are taking the engine out you probably should replace the main gearbox bushing as it does wear faster than most of the other mounts. Perhaps the engine mounts also require replacement.
    I wouldn't be too scared to drive the car. If you keep a close eye on your coolant temperature and level and also examine your engine oil for traces of contamination you should be ok.
  8. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,760
    US of A
    Michael
    Sure, the Tubi could be giving you the sound you describe.
    Absolutely.
    The head gasket can be subjected to corrosion if the car has not been maintained well, or has been abused again & again perhaps exceeding its holding capacity. However these cars are robust and can put up with lots of hard use. But... If the coolant has not been changed regularly that alone could have contributed to fatigue of the head gasket and a failure of the seal between two cylinders during an extended storage period.
    The computers on this car will not pick up a low cylinder reading per-say. But they will pick up a foul reading BECAUSE of the low cylinders as the fuel trim and or 02/converter readings will be skewed if its serious enough.
    A major will not take care of cylinders filling with coolant. The original reason why your tech said not to drive the car is that he feared hydro-lock (where a cylinder fills with fluid and then you crank it over giving no place for the fluid to go - therefore things like connecting rods and valves get bent). If indeed the coolant is filling the combustion chamber you will need to remove the head to diagnose the issue with the gasket.
    Understood
    As I see it you should get the compression readings and post for us to see if you would like. Then proceed with a leak down test again posting for us to see results. At that point you can formulate a general impression with your tech and follow the procedure that makes you happy.
    My initial impression is that if you are driving this car without concern or malady that you may just need a regular full service and then continue to drive happily. Confirming the pressure readings would help with that assumption.
  9. kaamacat
    kaamacat Formula 3
    Jun 13, 2004
    1,623
    Cumming GA
    BobR
    A few suggestions here:
    If owning the car for just (3) days, if I read that correct, I would do whatever it takes to get that car back to the seller for a refund. That would indicate you purchased a vehicle with a known problem and the seller wanted to dump it on someone else. (If that was the case). I know that "refund" sounds like a small word but, the ultimate cost here, if in-fact you have a head-gasket issue not a small task. Not only do the heads get pulled, but, you really want someone that knows how to do this work and fully check the head as-well. The damage could be (sure) just a head-gasket, but, could also be the head itself.
    On the water loss side. If you did have a bad head-gasket, the water is taken into the cylinders which is below the valves. The head gasket position is between the cylinder block and the head assembly, not from above. (If it were from above you would have a much more serious issue then such as a defect in the head itself, crack of sorts from a critical overheating issue that may have taken place)
    Typically when you loose water with a bad HG, on your intake stroke (piston downward, intake valves in open position), not only are you taking in fuel/air mixture but in this case water leaking into the cylinder area from a bad what-I-call fire ring that surrounds the cylinder bore itself. It "burns" with the mixture, you'd see some form of condensation/smoke from the exhaust (with a sweet smell possibly). Additionaly a HG leak would also (possibly) cause your overflow tank to rise quick because, on the compression stroke (piston up, valves closed) the compressed mixture would attempt to force its way back into the water system. The mechanic can check for this with a pressure gauge on the overflow tank.
  10. andrew911
    andrew911 F1 Rookie
    2,893
    Northern NJ
    I don't know about the other stuff you're asking about, but the occasional small backfire/popping sound you may hear when lifting off the gas is normal, and more easier heard with a Tubi vs. stock muffler. Mine does that sometimes (as you say, it's inconsistent- not every time I lift my foot off the gas), and I'd like to add that I love the sound of it when it does happen!!
  11. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner Rossa Subscribed
    Jan 19, 2004
    7,804
    San Jose, California
    My opinion: Send it back. A blown head gasket in an all aluminum motor could potentially be catastrophic. A major service is not going to fix this, or any other cause of two cylinders having low compression. I cannot see cracked headers causing low compression either. Head gasket, rings, valves, warped head, scored cylinder wall - these are the things I think about when I think about low compression. Just thinking about this is making me ill.
  12. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    From your presented information; You do not have an issue. All symptoms seem about normal, the shake could be anything from motor mounts to plugs or Coil over packs. Head gasket failures usually dont cause shake from fouling because the mixture loves water (in small amounts). Ever heard of water injection.
    If you have a major head gasket leak the symptoms will include:
    a. Water in oil (sometimes)
    b. White smoke at startup and maybe while driving. (almost every time)
    c. Coolant loss, i.e. the coolant tank level will drop. You can measure this yourself. (every time)
    I do agree better safe than sorry; here is my list:
    1. Post compression numbers from your mechanic
    2. Have mechanic complete leak-down test, very standard procedure. Post results here.
    3. Check OIL for water.
    4. Measure coolant level, drive, let idle, temp cycle a few times, remeasure level. If its about the same you are at no risk of hydra-lock.
    5. Get a second opinion from a recommended Ferrari mechanic, maybe a dealer. Its a small price to pay when comparing to an engine out repair.
    The F360 has many normal failures (weak spots), head gaskets are not one of them.
    If it were my 360, I would just drive it and keep an eye on coolant levels, exhaust at cold start (have someone else start it), and see if the symptoms progress. An engine out head gasket repair is so expensive, your risk/reward is looking good.
    Good luck, and most importantly keep this thread updated!
  13. SoftwareDrone
    Jan 19, 2004
    7,804
    Low compression in two cylinders = no issue? Yikes!
  14. vrsurgeon
    vrsurgeon F1 World Champ
    16,454
    Charleston, SC
    Curt
    Trent is IMHO 100% spot on. I would follow his advice....
  15. mowater
    May 24, 2004
    362
    Hi FD, nope, actually I did not notice any loss in coolant nor any temperature raise.
    IN FACT, I am rather stunned by how cool the coolant & oil temps are in the 360! In Kuwait it is winter now, and the average is 15 degrees C, and I am getting as low as 70 degrees C in the coolant and the highest is around 100 but this is of course when I am in stop-go traffic. Once I get the car rolling and up to more than 90km/h it drops back to 70-80 degrees C!
    This is very impressive to me because it is exactly like my SL55.
  16. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Hmmm lots to consider.......
    Your coolant temperatures seem to be fine - very much same range as my own 360 which is also calibrated in degrees C
    You don't appear to be loosing coolant - good.
    Your mechanic may have done compression test (which is relatively easy and quick to do) and not done leak-down (which takes longer and is a little more complex). If he did do the compression test, he really should have made a record of all the values and be able to give them to you.
    I'd say go ahead and book the car in to have the main service done but tell them that you want your compression tested first and if it's bad tell them to give you the results and post them here before they carry out further work. There's absolutely no point doing a belt change, oil change, major and then having to come back and split the engine a few months later.
    The gearbox mount is pretty easy to diagnose. You can visually inspect it and if it's way gone (like mine was) it's pretty obvious. Another tell-tale would be if the exhaust tips aren't nicely centred in the outlet through the rear bumper. The gearbox mount number is 186698. It's really easy to replace if you have the gearbox off the car, quite a bit harder with it still in there but very possible. Here's a link to my DIY thread.....http://www.ferrarichat.com/forum/showthread.php?t=331587&highlight=diy+gearbox
    Best of luck and keep us informed!
  17. mowater
    May 24, 2004
    362
    FD, thank you sir.
    Yes, thankfully, it seems the coolant issue can be totally disregarded.
    I thankfully revived my email account (was blocked) and was able to tell Daniel at Ricambi to go ahead with my order of the Major Service Kit.
    I totally agree with you that there is absolutely no sense in performing a major without making sure the engine does not need further, more complicated, work.
    Once I recieve my service kit, I will pass by the shop and ask for a Leak Down test.
    As for mounts (engine, trans) as well as ball joints or bushes, I will leave that for later.
    I wish to express my EXTREME gratitude for everyone here for their help and guidance.
    I now know a lot more than when I started.
    If I get any numbers, or have any issues (hoping not) I will make sure to report back here.
    Kindly feel free to add any further comments or opinions, and if members have symptoms of their own, they are welcome to discuss as well and make this a team effort.
    Best always,
    Ali
  18. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,760
    US of A
    Michael
    You sir are a pleasure to work with. Best to you.
  19. mowater
    May 24, 2004
    362
    Thank you sir! :)
    Went ahead and ordered the pair of head gaskets along with the major service kit from Dan.
    Will most likely perform the service with the engine out anyway.
  20. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    I have a set of heads sitting on my garage just in case.
    I sent it to get cleaned, port and bore. The change all the valves seals abd check all the valves just to be perfect. It includes the complete head, I mean camshaft ect. Just take yours out and install the new ones.
  21. BANANA
    BANANA Formula Junior
    Apr 21, 2007
    349
    1. I suggest that you get a second opinion
    2. My cars back in the UK spend about 10 months a year in storage while I'm in Dubai and this has been happening for the last 3 years. The only issue I have is batteries, servicing and flat spots on the tyres. Apart from that every summer when I'm back in London they run perfect. You say that your car has not been used for 6 months only which as far as I'm concerned is not an issue whatsoever.
    3. Changing head gaskets and skimming the heads is a lot of work so just make sure that you actually need to have that work done. It is difficult to diagnose something online but I don't think that you actually have a head gasket problem.
    Regards
  22. mowater
    May 24, 2004
    362
    Care to share pictures please of the heads sitting at the garage? :)
    As for your last comment, you mean take out the old head gaskets and install the new ones?
    Thank you for that my friend. :)
    Yes the car has not been used for 6 months BUT I was refering to the fact that it has 44,000km and is a 2000 model.
    To be honest, I consider that to be low mileage even for a tiny country like Kuwait.
    The weather here is unrelenting, as I am sure you can attest since you live in Dubai. :)
    I will most definitely only change the head gaskets when I am convinced, personally, that it needs to be done.
    Speaking with another mechanic from the same shop, whom I consider a close friend, he did confirm that there was water found on the spark plugs. This is where the diagnosis came from.
    And if I may just confirm a thought that crossed my mind:
    I understand taking the engine apart is no easy feat, but this shop is one that I trust (and not the same one that I have had issues with working on my F355), however are you gentlemen referring to the costs involved?
    Or is it a matter of being worried that the engine being taken apart and then back together could yield problems?
    In other words, the advice and hesitation regarding performing the head gaskets: is it a cost issue or a matter of fear for the motor itself if not done right?
    Cost wise, labour here is nothing like in the US/Europe.
  23. mowater
    May 24, 2004
    362
    Side question
    Apologies if this is trivial, but as a F355 owner as well I am kind of screwed in the head when it comes to F1 units LOL.
    Taking the engine out has NOTHING to do with the F1 system needing bleeding once everything is back in and running?
    I know the bleeding process is related to the tank and pressure in the unit, but forgive me for wanting to be one million percent certain. :)
  24. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    Ok. I will post pictures when I get home. The heads came from a spare engine I bought. You always need new head gaskests when you remove the heads(just be safe).
  25. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    #25 FerrariDublin, Dec 16, 2011
    Ahh! This might be a different problem. Are they saying that they found coolant in the spark plug recess / ope? As per this video.......?
    [ame]http://www.youtube.com/watch?v=ynjuzYuzQrc[/ame]
