F360 - "Engine Misfire" ? | FerrariChat
Discussion in '360/430' started by csteve, Jun 27, 2009.
  1. csteve
    csteve Karting
    May 6, 2006
    172
    hong kong
    steve chang
    Keep on getting "Engine Misfire" error code from my Engine Warning Light. Have you had the same problem?
  2. Derek Trotter
    Derek Trotter Formula 3
    1,790
    Cambridge, UK
    Shortly after buying my 360M, I had an intermittent mis-fire which OBD'd cylinder 6. Change of all 8 plugs and no problems since.
  3. csteve
    csteve Karting
    May 6, 2006
    172
    hong kong
    steve chang
    thank you...i just had my spark plugs replaced 3 months ago. thanks for the suggestions!
  4. csteve
    csteve Karting
    May 6, 2006
    172
    hong kong
    steve chang
    dealer just rang me back said CEL "throttle self-learning error" and "engine mis-fire" were result from air-flow meter malfunction. this maybe caused by K&N air filter. Hope this info can be useful for those who are considering K&N filter.
  5. Derek Trotter
    1,790
    Cambridge, UK
    I've had my K&N's for nearly two years with no issues. Doesn't sound like a K&N fault.
  6. bigme
    bigme Karting
    Nov 24, 2006
    98
    Illinois
    I have GruppeM Intakes for 2yrs and no issues. Have the dealer prove it, its simple as putting the old K&N back on and drive till you get the error again.
  7. k4site
    k4site Rookie
    Oct 3, 2006
    44
    Check the connections on the MAF, mine was doing the same thing and one was loose
  8. csteve
    csteve Karting
    May 6, 2006
    172
    hong kong
    steve chang
    thank you
  9. txhansen
    txhansen Karting
    Nov 30, 2003
    76
    Highland Village, TX
    Rich Hansen
    I would not be surprised if it is not MAF due to the K&N. It is easy to get too much oil on the filter which instantly ruins the MAF. A common problem on Porsches.
  10. csteve
    csteve Karting
    May 6, 2006
    172
    hong kong
    steve chang
    My car is killing me: I replaced all spark plugs, both airflow meters, fuel pumps, replaced k&n air filter by stock air filters. At the end of day I'm still getting engine mis- fire on cylinder 1. The Ferrari dealers seemed clueless.
  11. swilliams
    swilliams Formula 3
    Jun 14, 2006
    1,407
    Bowling Green, KY
    Scott
    #11 swilliams, Sep 30, 2009
    Sounds like time to check compression, for a vaccum leak around the intake manifold or for a faulty injector, or the most likely the coil on cylinder number 1.
    Who recommended the fuel pump???? If your dealer did then I'd recommend going elsewhere.
  12. PAP 348
    Dec 10, 2005
    100,216
    Mount Isa, Australia
    Pap
    +1!! :D:D
  13. technician F
    technician F Karting
    Sep 15, 2009
    57
    you change the fuel pump,spark plug,air flow meter,air filter the miss fire error code still coming on and engine run roughly.you can check the ignition coil ok or not.If it is ok,you must check the intake manifold gasket at cylinder no.1.this is common problem in F360.this is easy to check.You can spray the caburator cleaner or WD40 around the cylinder 1 intake mainfold gasket when engine is running.If leakage here,some vibration from the engine or intake sound from leakage area by the cleaner go into the engine directly.
  14. TAFORZA
    TAFORZA Formula Junior
    Jun 5, 2008
    296
    San Francisco, USA
    Tony A.
    If you did all of these things already, have someone qualified check the timing. Missifre codes especially on #1 cylinder are many times due to slightly off timing. All it takes is an incorrect timing belt tension on one bank to cause a missifre code.
  15. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    I agree. Changed lots of those intake gaskets because of this.
    I would swap out the coil from number one with one of the others and see if the misfire jumps cylinder. Faulty coil packs are also common on these. Often exessive plug gaps can cause premature failure of the coil.
