f360 f1 problem !!!need help please | FerrariChat
Discussion in 'Technical Q&A' started by kzsport, Apr 9, 2009.
  1. kzsport
    kzsport Karting
    Feb 23, 2008
    112
    china
    BRIAN
    Hi
    I have 2001 f360 f1...The f1 system have a problem below this..
    The transmisson light Scintillation when key turn on and start ......can't work now...
    Because I want to try find the failure by myself....what should I do setp by step???
    Thanks for everything
    -Brian
  2. FerrariEngineer
    FerrariEngineer Karting
    85
    ww.exoticars-usa.com
    Serkan Ozsavasci
  3. kzsport
    kzsport Karting
    Feb 23, 2008
    112
    china
    BRIAN
    The transmession light on when the key turn on not start engine that engine is hot.....after start engine F1 system still can't work....But wait for half hour restart key turn on and start engine the F1 system can work for 1-2 minutes then problem around again....
    I'll goto dealer on tomorrow for check error code then post on this....VIN number also.....
    thanks for your help
    -Brian
  4. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Sounds like the clutch slave is sticking. 360's from this era are prone for it, they changed the specification of the seals. Once they have some heat into them they stick, the P.I.S reading from the sensor is wrong and it won't let you select a gear or even start the engine. Once it all cools down again for a while it starts working again. Your dealer will be able to see this occuring by getting the car hot and reading the P.I.S value with an SD2.
