F360, Flasher, Turn Signal, Hazard Problems | FerrariChat
Discussion in '360/430' started by ohared, Apr 29, 2011.
  1. ohared
    ohared Formula Junior
    Apr 14, 2009
    325
    I have Flasher, Turn Signal, Hazard Problems on my F360.
    Original problem started with a flown 15amp fuse in the luggage compartment.
    This seems to be linked to issues with the flasher relay in front footwell. However, in trying the trace the origin of the fault we are blowing flasher relays (or perhaps damaging them ?). We now cannot get a consistent & reproducible fault. Sometime it works for 10 mins and then the next time you use it it blows the fuse.
    The problem is always on the right side turn or turning on the hazard switch. We have checked earths to all the bulbs, continuity on the live side from the relay to left and right bulbs and cannot fault it.
    I have been searching on here and there is some history with this relay.
    However, I have no feeling of the kind of symptoms people have experienced, and if they also got this strange inconsistent behaviour, and if so why ?
    Who is the guru on this one?
    Dermot
  2. rotaryrocket7
    rotaryrocket7 Formula Junior
    Dec 7, 2011
    625
    Eden Prairie, MN
    Matt
    Did you ever figure this out dermot? I'm having the same problem and haven't found a short yet, however pin 5 in the relay (which is the right signal lights) will short a fuse if I use a jumper and connect 12v to it. The left side, pin 6, lights up all three indicators.
  3. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    Have you check the blubs and bulb sockets for broken casings and such.
