News
F360: my front fender is cracking... any clue ??
Discussion in '360/430' started by henkie, Nov 12, 2007.
  1. henkie
    henkie La Passione...
    Apr 13, 2005
    10,455
    Deil,The Netherlands
    Henkie
    #1 henkie, Nov 12, 2007
  3. cig1
    cig1 F1 Rookie
    May 3, 2005
    2,869
    In front of you
    That's your bumper, at least on this side of the pond, it's called a bumper.
    Hitting the floor could probably cause damage like that
    G
  4. Rockyd
    Rockyd Karting
    Oct 5, 2007
    117
    San Jose
    If you did not roll your fender and you lower it ; your fender will definitely crack .
  5. brokenarrow
    brokenarrow F1 Rookie
    Sep 25, 2006
    3,646
    Txass
    Bill
    My guess is that it has been the victim of a speed bump or hitting a curb on the front. See if you have any bad road rash on the underside of the bumper.
  6. Tipo815
    Tipo815 F1 Rookie
    Nov 1, 2003
    3,493
    Newport Beach, CA
    Jeffrey
    As Cig 1 mentioned that is his BUMPER and not the fender. Depending on how hard you're scraping on the driveways I would imagine that it could cause cracks like that. Do you scrape everytime you drive into or off your driveway? Did you accidentally hit the underside of the bumper hard recently? Maybe going over a dip in the road too quickly?
  8. porsche racer
    porsche racer Formula Junior
    Jun 2, 2006
    747
    southern california
    arthur
    IMO Because it's on both sides and same area, it's by hitting the ground and bending the sides of the bumper inward.
  9. henkie
    Apr 13, 2005
    10,455
    Henkie
    Excuse me for the fender / bumper confusement.
    Well, we have those terrible speedbumps here in Holland... so perhaps it could be the guilty part. I have some bad scraping spots....unfortunately.
    I think the bumper is attached to the body exactly at the spots (behind the bumper) ?
    But.. (as there are lots of 360's around here)... nobody has ever seen this problem as I understand?
  10. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Time for a CS bumper IMO....;)
  11. India Whiskey Charlie
    India Whiskey Charlie Formula Junior
    May 24, 2001
    554
    Way Out West
    FWIW, I had a 2000 360 which developed this problem on the front bumper very early on since new. No lowering and/or scraping. The local body shop fixed it to perfection under warranty. At about the same time, a friend who also had a new 360 had the same problem. I assumed it was a somewhat common problem with early 360's.
  13. $$$=SPEED
    $$$=SPEED F1 Veteran
    Aug 18, 2004
    5,289
    Portland, Or. USA
    Depends who's asking
    BONDO??? sorry bad joke
  14. Testacojones
    Testacojones F1 Veteran
    Nov 3, 2003
    5,139
    Terra
    I had the same problem on my '01 360, it was a pain and I think the best fix is to buy a new one.
  15. Murph
    Murph Formula 3
    1,539
    SoCal
    Kevin
    Bumper or car?
  16. Derek Trotter
    Derek Trotter Formula 3
    1,767
    Cambridge, UK
    And by the looks of your tyre, you need a new one!
  17. Valence
    Valence Formula Junior
    Jan 20, 2004
    875
    Charlottesville, VA
    Chris& Brian Coffing
    It's not your fault, Henkie. These bumpers are not molded in one piece, rather they are multiple pieces glued together. In this area, the air vents curve inside the bumper, and this shape would be nearly impossible to mold efficiently - it's called an undercut. So, the bumper molder made 2 separate air vent pieces and glued them into corresponding holes in the main body of the bumper. If you look inside the bumper with all the shields off you can see this clearly. The outside is sanded and faired, then painted. Over time, with flexing and temperature changes, this seam opens up a little bit and the paint cracks along the seam.
    There are some rather technical fixes that could solve this pretty much forever, but I bet if you just sand, fill, and fair the area, and repaint it, you'd get years more good service from the fix. There are fillers made for flexible parts like urethane bumpers, and also flex additives for paint. Using these might help keep the problem from reappearing.
  18. Hubert888
    Hubert888 F1 Veteran
    5,376
    Manhattan & LA
    Hubert
    u just answered your own question homie
  19. Testacojones
    Nov 3, 2003
    5,139
    Terra
    New bumper. Mine was repaired twice and it was on the way to happen again and it was a lot of money to get fix on both incidents. The paint, the clear film, the trials to figure out how to prevent the problem, the time in the shop and then having to take it back after a few weeks... A real pain in the azz.
    The 360 bumper side air outlet was the problem just like the pictures above. If you take a look at the bumper from the inside you'll see that the bumper is built with a hole and the outlet is glued into this hole and that might create a problem on some 360s.
  20. henkie
    Apr 13, 2005
    10,455
    Henkie
    @Valence & other people
    Thanks for your kindly replies. The situation is clear for me. I'm gonna try with a complete repaint at the expert and if I'm lucky I won't see this problem again the first 2 years.
  21. fc2
    fc2 F1 Veteran
    Nov 2, 2006
    5,136
    Silicon Valley Ca.
    Frank C.
    Of course if Ferrari would put a front-end lift capability in their cars like Lambo does, this wouldn't be as big an issue. Having driven G-cars a few times, it's SO nice to hit the button and drive straight into a driveway or over the speed bump etc.
    If they made this an option, I think most 430 owners would go for it, I sure would.
    Frank
  22. Testacojones
    Nov 3, 2003
    5,139
    Terra
    The problem with my car didn't have anything to do with the front bumper hitting on anything and that includes every scenario, it just happened.
  23. OneofMillions
    OneofMillions Karting
    Nov 8, 2007
    128
    Toronto, Ont
    Christian L.
    #20 OneofMillions, Nov 14, 2007
    I have a similar problem in mine. I think it was caused when the cat bottomed out at the front, but this cracking only showed up much later (months) after that bump. Still not sure what's going on. 2001 360 spider, 5k miles
