F360 soft top problem | Page 2 | FerrariChat
Discussion in '360/430' started by 3s-ge, Apr 10, 2021.
  1. Qavion
    Qavion F1 World Champ
    14,210
    Ian Riddell
    Sorry, I'm not familiar with the roof system at all on 360. I'd better leave this to the experts... but... sometimes a picture is worth a thousand words. Is the hex designed to be a manual override or is adjusting the hex simply having a side effect on the microswitch (say, allowing the ram to move more in a certain direction). Either way, it sounds like something is bent or there is a pressure or ram fault. On the F355 roof for example, sometimes the rams get bent and the ram doesn't extend fully (and the internal microswitches don't get activated). The switches on the 360 seem to be mostly external. I don't know if this a good or bad thing.
    I don't know if you have this file on the 360/430 roof system?
    https://www.dropbox.com/t/xZLqVPAbMStdtrQ1
    It shows what signals are to be expected with the roof in a certain position. It probably won't help in your situation, however.
  2. parkem
    parkem Karting
    Feb 17, 2012
    160
    florida
    peter palermo
    it allows you to manually open the ram (locks)
    Qavion likes this.
