360 - F360 Spider Won’t shift into gear | FerrariChat
360 F360 Spider Won’t shift into gear
Discussion in '360/430' started by Stout360, Jan 13, 2024.
  1. Stout360
    Stout360 Rookie
    Jan 13, 2024
    3
    David Schutzbank
    Hi All,
    My F360 spider had a dead battery while in the paint shop. The battery was charged up, it will start but won’t go into gear. It’s an automatic.
    This red dash light is blinding while the car is running. I heard it might be the F1 pump or relay? Any insights how to test those parts or manually prime the F1 pump?
    thanks,
    Dave
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,935
    Central NJ
    Dominick
    #2 flash32, Jan 13, 2024
    Hoping that they didn't "boost" car while trying to start it
    Hoping they didn't weld anything
    Try disconnecting battery for a hour and then connect and see what happens
    A diag tool to read codes will be necessary to see why code is on
    Guessing at this point is pointless
    What year is the car ?
    cavlino likes this.
  3. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,166
    Wash DC area
    Robert
    Looks like your deck lid is up and not latched down.
    That locking mechanism can be real touchy.
  4. Qavion
    Qavion F1 World Champ
    14,299
    Ian Riddell
    @Stout360 Are you getting an engine lid open warning? Is your foot on the brake?
    From the WSM:
    Engine Compartment Lid Switch
    The "lid open" message reaches both the TCU and the alarm system ECU, through an ON-OFF switch that
    closes the circuit to ground.
    If this happens, with the car at a stop, the engine running, a gear engaged and foot brake/accelerator pedals
    untouched, the system activates the acoustic alarm and releases the gear setting itself in neutral position.
    The switch is placed on the respective opening device (H 2.13).
    Also:
    • With the engine running and the car at rest, if the driver's door is opened without pressing the brake pedal,
    the gear is automatically disengaged and shifted to neutral.
    Is your foot on the brake? Is your brake pedal switch working?
    Experts: will this stop a gear selection or will the gear select, then fall back to neutral?
    flash32 likes this.
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,935
    Central NJ
    Dominick
    Great catch .. didn't even think of the obvious .. can't make out car symbol in info display .. but def can be showing lid is up
    E60 M5 likes this.
  6. Qavion
    14,299
    Ian Riddell
  7. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,166
    Wash DC area
    Robert
    Yes, I have had instances were I had to press real hard on the brake pedal to get engagement from the gear box.
    Although this was usually after parked on an decline with emergency brake engaged.
  8. Qavion
    14,299
    Ian Riddell
    Does any of the logic in post #4 generate an F1 warning light (as seen in the photo)?
    Experts: Does the emergency brake repositon the brake pedal or make the pedal harder to move away from the brake pedal switch? I've heard of hydraulic issues limiting the travel of the brake pedal, but are hydraulics involved in the emergency brake system?
