F40 alternator/water pump belt tension? | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by Bill S, May 1, 2010.
  1. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    #1 Bill S, May 1, 2010
    Can anyone recommend how to adjust the F40 alternator belt tension? The manual says 130-135 using a Staeger type tensioner. Where do you buy one or is there an alternative?
    My belt broke today so I'm guessing the tension it important and I had it too tight.
    BTW, when the belt broke the battery light came on and then the water temp light a minute later. The water temp shot up and I shut down the car and flat-bedded it home. The overflow tank was spilling coolant.
  2. Wittsy308
    Wittsy308 Karting
    Feb 2, 2008
    170
    California
    Paul
    Hi Bill,
    I use a Clavis Type 4. Fabulous bit of kit, though i'm sure there are others out there.
    http://www.clavis.co.uk/
    Sure hope you're F40 is ok and you shut her down in time.
    Cheers
  3. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    Typical, when the belt broke the alternator lost power and the battery tried to take over....get that belt torqued right and you should be good to go!
  4. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    Thanks. When Ferrari says 130-135, what are the units?
  5. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Cool bit of Kit!
