F40 and F50 and speed bumps | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by jayfive, May 21, 2010.
  1. jayfive
    jayfive Rookie
    Jun 6, 2005
    16
    off the wall question for anyone, can a f40 or a f50 get over a uk spec speed bump, even the stupid ones that are like a little pyramid in the middle of the road :)
  2. ryankjb
    ryankjb Formula 3
    Nov 19, 2006
    1,071
    NJ
    Ryan
    The F50 can raise the nose up, so I would assume it could make it over one.
  3. rossocorsa13
    rossocorsa13 F1 Rookie
    Jun 10, 2006
    2,557
    Nashville, Tennessee
    M
    There are also aftermarket pneumatic (I believe) systems for both cars.
  4. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    There are a few guys in here who have UK based F40's. From what I have read you have to go slow, but they can make it.
  5. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,448
    ESP
    Bas
    Scrape scrape scrape :D
    Get a Roberuta front lifting system. IIRC around $2500. Brilliant little system and ride isn't affected whatsoever...There are a few Time attack cars who have it on there.
  6. Simon^2
    Simon^2 F1 World Champ
    Oct 17, 2005
    12,313
    At Sea Level
    Some euro F40's have the factory original optional nose lift system. But not sore that helps... the nose lift is more for changes in angle of pavement at driveway entrances and garage ramps.
    I never measured chin spoiler height vs mid car minimim ride height. I suspect they are close... so if the nose wont clear, the car woulld likely bottom out when the speedbump is between the axels...
    I avoided all speedbumps in my US car.
  7. frefan
    frefan F1 Veteran
    Apr 21, 2004
    7,370
    F50 will be no problem for sure
  8. F50CHAP
    F50CHAP Karting
    Nov 20, 2007
    77
    uk
    matt
    No problem with my F50. Just chose your line carefully!
  9. George330
    George330 Formula 3
    Oct 19, 2009
    1,435
    Switzerland
    George
    The F50 is not a problem. The adjustable suspension clears all speed bumps, but you can also clear most of them without raising the car if you choose your line carefully
    On the F40: cars fitted with adjustable suspension can clear all speed bumps. Cars without adjustable suspension can only clear small speed bumps and they scrape the front bumper on all others
  10. stradman
    stradman Formula 3
    Jan 8, 2004
    1,284
    London UK
    Stradman
    Ditto on that. No problem with the adjustable suspension cars, which is why they are invaluable in city driving. I basically would not be able to get my car up a portion of my driveway if it wasn't for the adjustable suspension!
