F40 Clutch feel question | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by RufMD, May 22, 2006.
  1. RufMD
    RufMD F1 Rookie
    Jan 31, 2004
    3,246
    Jas
    I don't know if this is just in my head, but here goes...I have driven my CGT alot lately, and it has a stiff clutch...my F40 clutch seems lighter to me lately..
    The clutch throw on my F40 feels lighter for the 1st half of its travel, almost like it has lost its spring tension. The car engages fine, shifts fine, but it appears that the engagement point is a little lower than before. The car has not been abused, and the symptoms arose after the car had been sitting for about 2 weeks.
    I think it is a small pressure loss somewhere, or maybe it just needs to be bled ? There are no fluid leaks anywhere that I can see, and the car has not been abused with burnouts or clutch riding...
    I think I'll start with a simple clutch bleed...anyone here done it on an F40 ?
    thanks...
  2. 410SA
    410SA F1 Veteran
    Nov 2, 2003
    8,511
    West Coast
    A
    My F40 clutch feels extremely light and with a very linear takeup. After I've driven the CGT the F40 clutch seems like something on a Kia.
  3. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    The F40 has a problem with the magnesium bellhousing that contains the clutch slave cylinder. The alloy used produces gas bubbles that are trapped in the slave cylinder. The bellhousings require removal and coating to prevent this from happening. From memory I believe that I used the Tagnite coating process (Mil-Spec process used on helicopter castings) on the last one and was quite happy with the results. Simple bleed out will fix for the time being.
    Dave
  4. BMW.SauberF1Team
    BMW.SauberF1Team F1 World Champ
    Dec 4, 2004
    14,428
    FL
    Ah...the F40 clutch. It's the heaviest clutch I've ever felt. Simon kept telling me otherwise, but maybe I just have chicken legs. :D
  5. dan360
    dan360 F1 Rookie
    Feb 18, 2003
    2,669
    Boston
    You should drive one of the early TVR V8 cars, the first time I drove one I thought I'd pressed the brake pedal with my left foot...
  6. Simon^2
    Simon^2 F1 World Champ
    Oct 17, 2005
    12,313
    At Sea Level
    F40 clutches are quite light, comparitively. Both 512TR's I've driven have signif heavier clutch, than my f40.
  7. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Thats how I feel it as well. Very nice pedle effort.
    Dave
  8. RufMD
    RufMD F1 Rookie
    Jan 31, 2004
    3,246
    Jas
    Thanks, I'll try the bleed and see if that improves for now..
  9. RufMD
    RufMD F1 Rookie
    Jan 31, 2004
    3,246
    Jas
    Does anyone know where the clutch bleed valve is located ? Which part of the bellhousing ?
    I figure the pedal feel should improve after a bleed, if not, its off to the service man !
  10. F40LMGTC
    F40LMGTC Formula 3
    Mar 15, 2005
    2,457
    AUSTRALIA
    GIL MATTHEWS
    Drive a 512 Boxer, then you'll know about heavy clutches.
  11. BMW.SauberF1Team
    Dec 4, 2004
    14,428
    FL
    How would you say the standard F40 clutch compared to the F40LM? That is of course if they are different.
