F40 front wheel bearings | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by mrknowitallf40, May 7, 2009.
  1. mrknowitallf40
    mrknowitallf40 Formula Junior
    Feb 20, 2005
    306
    If you own an F40 you should inspect the condition of your front wheel bearings. The wheel bearing rides on a race that is machined into the upright. The entire assembly has no seals of any kind to keep out water and keep grease in. Allowing this assembly to run dry could be quite expensive. Mine were on the verge of failure. I assumed they were sealed bearings as on the rear. I would think that by this time every F40 would need servicing.
