F40 Motor Oil | FerrariChat
F40 Motor Oil
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by Drew Altemara, Jan 14, 2013.
  1. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,532
    Tuscaloosa, AL
    Drew Altemara
    #1 Drew Altemara, Jan 14, 2013
    What motor oil are you guys running in your F40?
    When I initially had the car serviced the dealer use Shell 5W40 synthetic with the picture of the Ferrari shield on the bottle. The operating manual specifies 10W40.
    Was thinking of going with Shell 5W40 synthetic or Mobil 1 0W40. The only quality 10W40 I can find is Mobile 1 but in that viscosity range it is extended wear.
    Any thoughts.
    Appreciate,
    Drew Altemara
  2. frefan
    frefan F1 Veteran
    Apr 21, 2004
    7,370
    Royal Purple 5W40 here
  3. 85886
    85886 Karting
    Feb 22, 2012
    134
    10W60 gives you more margin at high temperatures.
    A clear recommendation by the experienced workshops and concessionaires I know.
    Shell and Agip are the typical choices. I'm happy with Shell.
  4. kverges
    kverges F1 Rookie
    Nov 18, 2003
    3,179
    Dallas
    Keith Verges
    Motor Oil now is a lot different from Motor Oil in 1987, mostly for the better. Lack of ZDDP worries me, but the quality of a good synthetic oil from Mobil 1, Shell, Agip, Castrol are all excellent and as good or better than anythign in 1987.
    I personally use the Mobil 1 0W-40 or 5W-40 sythentic - the 40 is the hot viscosity and IMO the lower the viscosity cold the better on startup.
    What I think is one of the best motor oils on the market for street use is Mobil Delvac 1 (yes I nkow it is designed for diesel vehicles, but it has additives that are just fine for gasoline engines - only question being if it might have too much ZDDP)
    I don't know if a ZDDP additive makes sense in the F40. Too much is bad for the catalytic converters.
    Going with a 60 weight IMO is a bad idea unless you are actually tracking the car and getting the oil hot, as in 250 deg F or hotter.
  5. 85886
    85886 Karting
    Feb 22, 2012
    134
    The 10W60 is similar in its behaviour to a 10W40 at low and medium temperatures - as opposed to a classic 60, i.e. 20W60 (used for motorbikes like the Ducati superbikes).
    But when/where the oil gets hot the 10W60 is safer than a 10W40. That's why 10W60 is often used for turbo engines.
  6. kverges
    kverges F1 Rookie
    Nov 18, 2003
    3,179
    Dallas
    Keith Verges
    I have endurance raced turbo cars with oil temps of 250+ for 6 hours with no ill effects using Mobil 1 10W-40 and no ill effects. Nothign wrong with 10W-60 but for a street-driven F40 I personally don't use it and don't think it is necessary.
    If you really want to deep dive on oil, thsi is the best web site I have ever seen:
    http://www.bobistheoilguy.com/
  7. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    The best modern day equivalent would be Red Line 5w-40.
  8. frefan
    frefan F1 Veteran
    Apr 21, 2004
    7,370
    Correction; I'm running redline 5W40, not RP as previously stated. No particular reason, just that is what my mechanic put in it. My only complaint is the oil is so clear its almost impossible to see it on the dipstick. But I think that is a problem with other synthetic oils in general.
  9. sherpa23
    sherpa23 F1 World Champ
    10,008
    Rocky Mountains
    Bastuna
    #9 sherpa23, Jan 14, 2013
    I'm running Redline 5w-40. I buy it by the case since I started using it first on my 328 GTB 7 years ago. No one has ever said anything but great things about it.
