F40 Photos | Page 185 | FerrariChat
F40 Photos
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by TexasMike, Mar 5, 2006.
  1. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    Kevin of Mototechnique confirmed on here some time back that it is not even carbon kevlar weave that you see, and that in fact the first layer is simply fibreglass cloth, and quite straightforward to replicate the original sunken look by adding such a layer prior to a final thin coat of paint on a restoration. If you look closely in the corners of panels on some of the early cars you can see where basic fibreglass strand matt has been shoved in to bulk up the structure during the lay up, and the paint has sunk into that.
  2. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Here's my personal experience.
    As far as repaints go, it's known that a number of specialist coach-builders can replicate the 'weave' in the paint in a fresh repaint, you don't have to wait 2 years for a repaint to 'settle in'.
    I don't think it's correct to say 'the ONLY way to tell original paint is a sanding job', original paint can be verified without damaging the vehicle's paint by sanding it, although if the car's bodywork is being repaired anyway, that's a way to check.
    Under normal inspection circumstances of a car that does not need repairs, of course, as a start, if the car's records are available, they might explicitly state that the car has been repainted, as we have encountered several times.
    The simple reason why many F40 resources say that visible weave = original paint, is, most often, repainted cars have no weave at all. But it's not that simple, because many F40s left Maranello with no weave in the paint, whereas some had partial weave. F40 finish at the point of production wasn't as uniform as the next-generation F50 where the weave is both prominent & uniform across all body panels in all the cars which still have original paint. When they were new, 'weave' on the F40s may not have been as visible, but years later after the composite body panels go through many temperature cycles, the weave can become more visible. Upon physical inspection of the car, consider that the F40's original hand-painted single-stage paint is both thin and inconsistent, there are areas (usually the bigger panels) where you can clearly see the texture and weave of the body, and, there are areas where there is no weave apparent at all. The paint along seams and edges is visibly thin and has often been polished away. As is well-known, single stage paint means the color and the clear lacquer are painted in one layer of Glasurit Rosso Corsa as a mix, which is the case with original F40 paint. You can test this with a solvent in an obscure area and your light colored cloth will turn reddish with paint residue. Single stage paint is quite different to modern paint where there are essentially three layers, primer, color and then clear lacquer, solvent won't release any red paint residue from modern enamel Rosso Corsa paint.
    If you have experience inspecting F40s, having first determined if it is indeed single-stage paint, you can learn to tell upon close scrutiny if the paint is at least mostly original (with perhaps area repairs done in period) by observing the characteristics of the paint as it presents itself, F40s came from the Maranello works with characteristic overspray in key places, typical paint contamination, thin paint, and sometimes with paint drips in key areas.
    By the way, when checking F40 paint, my understanding is Glasurit Rosso Corsa FER 300/9 was introduced by Ferrari SpA in 1988, and Glasurit Rosso Corsa FER 300/12 was introduced in 1991, this explains why many a fair number of F40s have RC FER 300/9 paint code stickers, and later production F40s have RC FER 300/12 paint code stickers, this applies to both USA and Eu/ROW F40s.
    dariedell and sjp like this.
  3. bay
    bay Formula 3
    Mar 13, 2011
    1,275
    Belgium
    Bernard
  4. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
  5. FerrfanFL
    FerrfanFL Formula 3
    2,258
    Florida
    Ara
    no other car, for me at least, gives me goose bumps like seeing one. Ferrari made other magnificent supercars, but this one to me is beyond supreme. There is no second place. F40 is the KING...
    titangolf and Caeruleus11 like this.
  6. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
  7. FCD
    FCD Karting
    Nov 27, 2011
    170
    Germany
    Timo Seefeld likes this.
  8. dariedell
    dariedell Formula Junior
    Jul 12, 2021
    325
    United States
    Andrew Riedell
    Interesting teaser from John Temerian/Curated. For those who don't recognize that chassis #, it's the (now) gray heavily modified example that sold at B-J earlier this year and was promoted (unsuccessfully) by RM at Monterey last summer. It was yellow and an active racer in the 1990s-2000s.
    https://rmsothebys.com/en/auctions/sf22/sotheby-s-sealed---one-off-nardo-f40--competizione-/lots/r0001-1989-ferrari-f40-competizione/1283456
    https://www.barrett-jackson.com/Events/Event/Details/1989-FERRARI-F40-265451
    NürScud and BtvFerrari like this.
  9. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    #4611 PAUL500, Aug 27, 2023
    The facebook group is providing loads of gems
    Before anyone tries to shoot me down again, I know some may not be what they appear to be! still look good though.
    I have taken none of these, if the person who did wants recognition of such just let me know and I will add or remove as required.
    Quite a mix and match, easier to put them here then in the various F40 threads, I love them all despite claims to the contrary!
  10. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    #4613 PAUL500, Aug 27, 2023
    Serobson likes this.
  11. Moopz
    Moopz F1 Veteran
    5,556
    Orlando, FL
    Thread is here...
    https://www.ferrarichat.com/forum/threads/f40-80782.178761/
    Sent from my SM-S908U using Tapatalk
  12. GHG
    GHG Formula 3
    Jan 29, 2008
    2,134
    modena06, marko.urbac and dariedell like this.
  13. Warren Brown
    Warren Brown Karting
    Sep 5, 2010
    75
    Warren Brown
  14. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    New one of me, observations are :- no mirror, wrong mirror, no Pinninfarina badges, wrong wheels, missing front clam side grilles.
    It's not the yellow race one, and pics look old, correct wheelbase so not a 308/328 conversion. Bet its some sort of German tuning company mash up from the 90s for a middle eastern customer. That driver no doubt has a wet butt!
    GHG likes this.
  15. 250boano
    250boano Formula Junior
    Apr 27, 2022
    450
    Europe
    DD
    Front looks a bit Fiero-ish no...? Snubby one might say
  16. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Warren I've sent you a PM.
    What you are looking at are old images of something that's very clearly not a real F40.
    It's a fiberglass-bodied replica by a French-based company SEFAP/CMO Production who provided kits for the Ferrari 330 P4, F40, Lamborghini Countach, Diablo, GT40 etc. with prices starting at 21,500 Eu.
    They operated from circa 1990 till they went out of business 17 years ago in 2006 forum-auto.caradisiac.com
    modena06 likes this.
  17. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    ScrappyB likes this.
  18. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
