F40 RACING HEAD GASKET REPLACEMENT | FerrariChat
Discussion in 'Technical Q&A' started by FREECAT, Aug 2, 2005.
  1. FREECAT
    FREECAT Rookie
    Jun 18, 2004
    5
    Guys,
    I urgently need an F40 replacement head gasket for my racing spec'd F40.
    The standard one is not up to the job of withstanding 700bhp and 1.5 bar.
    Can someone let me know if a racing upgraded part is available anywhere, or who can fabricate one for me.
    Many thanks.
  2. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    Checked deck and heads before engine build?
    If you are blowing head gaskets at 21 psi then I would suggest either turning the wick down, or pull the engine and install O-rings like the LM engine.
  3. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    My guess is James Patterson at Norwood Performance can help you out.
    Philip
  4. ernie
    ernie Two Time F1 World Champ Lifetime Rossa Owner
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    You need to post this in the Super Ferrari section. Rick just finished having his angine rebuilt.
  5. vincer77
    vincer77 Karting
    Dec 12, 2003
    71
    You should give Tate at Carobu a call 949-722-9307.
  6. FerrariF1
    FerrariF1 Formula Junior
    Apr 29, 2005
    531
    Virginia
    Chris
    1.5 bar is not lot of boost. check and see if motor has detonation. check head gasket and see where it failed. check spark plugs and monitor afr, egt and knock sensor. o-ringing the heads or block is not going to save the motor from untuned engine. o-ringed heads with copper head gaskets requires lot more maintaining.
  7. TomDial
    TomDial Rookie
    Aug 6, 2004
    36
    Europe
    Chris
    Try Spesso in Italy for a ringed gasket, I run them on my turbo cars with great succes. It is a "normal" gasket with separate fire rings. They can take any boost while the gasket seals like a stock item. No need to machine block or head.
    They are around $200 for a 4-cylinder.
    Contact: Daniela Manini <[email protected]>
    Chris
  8. EfiOz
    EfiOz Formula Junior
    Jul 26, 2005
    850
    Lago di Legana
    Lucivius Maximus
    Cometic Gaskets
    www.cometic.com
    They make some nice multi layered stainless gaskets.
