F40 Restoration Project | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by Roberto Japanini, Sep 6, 2007.
  1. Roberto Japanini
    Roberto Japanini Rookie
    Aug 13, 2007
    26
    Kakogawa City, Japan
    Robert Dunn
  2. WILLIAM H
    WILLIAM H Three Time F1 World Champ
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    LOL just a little Bondo & that will buff out LOL
  3. F40org
    F40org Formula Junior
    Feb 2, 2004
    568
    Munich / Ft. Myers(FL)
    Rolando
    I know a guy in Germany who did the same work. If you will go in touch with him I can give you all the contacts. Which VIN is yours?
  4. Simon^2
    Simon^2 F1 World Champ
    Oct 17, 2005
    12,313
    At Sea Level
    If I was near the car, I'd buy it and sit on it for 30 years. Never restore it, but plan to sell it as a "barn find" 30-50 years from now... would likely turn out to be a fantastic long term investment for very little risk...
  5. Scuderia-San-Antonio
    Scuderia-San-Antonio Formula 3
    Feb 27, 2005
    1,567
    San Antonio
    Wes
  6. Simon^2
    Oct 17, 2005
    12,313
    At Sea Level
    I think he went for the aftermarket fitted luggage instead of the schedoni set... ;)
  7. Tipo815
    Tipo815 F1 Rookie
    Nov 1, 2003
    3,565
    Newport Beach, CA
    Jeffrey
    I think someone mistook it as a trash bin ... :D
  8. bert308
    bert308 Formula 3
    Nov 30, 2002
    1,776
    Roermond Netherlands
    Bert Kanters
    Wasn't the Lindner "LM" build on a base like this? Look how someone took out the front nose badge.
  9. Racerboy
    Racerboy Formula Junior Silver Subscribed
    Feb 3, 2004
    468
    Bay Area
    Where is this car? If it is in the US and they really want 12K for it I will buy it ASAP.
  10. RufMD
    RufMD F1 Rookie Owner
    Jan 31, 2004
    3,246
    Jas
    Not a restoration expert, but wouldn't that frame still be ok ? Unless something has melted, how does fire affect the integrity of metal ?
  11. nthfinity
    nthfinity F1 Veteran
    Mar 21, 2005
    7,467
    South East MI
    Isaac not Issac
    Depending on temperatures, but metal loses a lot of its tensil strength the longer at even farily "warm" temperatures.... 2 hours a 300F is better then 30 minutes at 400F.Tests can be preformed on certain aluminum's for example, and the level of fatigue it's suffered in the fire. I don't know quite enough about steel... but surely somebody on fchat knows much more about the steel, and what specific grade steel it is... and how well it takes the heat a car fire would produce.
  12. Chaos
    Chaos Formula 3
    Sep 29, 2004
    2,346
    Cardiff. UK
    Nick.
    i believe the first post says its in japan.
  13. peter5
    peter5 Formula Junior
    Aug 13, 2005
    519
    NoVa
    Without getting into "THAT" debate, maybe somebody should ask Napolis about 0846. I would guess that the fire that consumed parts of that car was very hot, and it would be interesting to know if he has had the chassis stress-tested to see if the driving characteristics were changed dramatically as a result of the fire. Would Nino have a strong enough recollection to notice a difference?
    Peter
  14. ^@#&
    ^@#& F1 World Champ BANNED
    Feb 27, 2005
    12,091
    an F40 LM in the making...
  15. RufMD
    Jan 31, 2004
    3,246
    Jas
    now thats funny !
  16. coachi
    coachi Formula 3
    May 1, 2002
    2,108
    SC USA
    me too
  17. WILLIAM H
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    I think what you would have to do is cut out the part w the VIN, since thats probably the only salvagable part of this car & rebuild the car around that
  18. Francesco_Baracca
    Francesco_Baracca Formula Junior
    May 18, 2005
    367
    Can someone give an answer to these questions:
    Is a restoration possible?
    How much of the existing car could be salvaged (based on the pictures)?
    And would the cost be less than purchasing a complete car?
  19. Alex1015
    Alex1015 Formula Junior
    Sep 1, 2005
    949
    I don't know if a restoration on that is possible. By the time you 'restore' it, it may have been cheaper to buy a whole one. Also, not much of that look salvageable. Does anyone know specifically what type of steel is used for the frame?
  20. gregmour
    gregmour F1 Rookie
    Dec 17, 2005
    4,193
    Valréas / France
    GREGORY
    Ithink no.........the production of this car is so big.
  21. WILLIAM H
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    Anything is possible, its just a matter of how much you want it, Read $$$$$$$$$$$$$$$$$$$$$$
    Like I said, I think you can salvage the VIN plate & that may be it
    as for 3rd question, well that depends on how much you buy from F, how much you luck into, and how much you are willing to have fabricated. I think the less F parts you use the lower the parts cost & you may have higher quality as well
    The engine of course HAS to be F but not the turbos intercoolers, exhaust,
    The interior could be pure race car
    I probably have near $200k into my race 512TR by now but she's a Monster and she can spank a whole lot of cars out there
  22. scud
    scud F1 World Champ
    Oct 2, 2004
    11,803
    looks like a world of pain . check the parts price from ferrari , probably need to spend $3 million to get it right .
  23. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    The chassis is a heat treated alloy similar to 4130 alloy tubing. Any time one welds on a race car chassis built from 4130 the surrounding area must be annealed to normalize the weld or embrittlement is highly likely.
    In this case the entire chassis was "annealed" due to the fire. To heat treat alloy tubing exposed to high heat there is a very specific slow cooling rate required. Pouring water on the chassis creates a quenching effect like used when treating a chisel.
    There are a lot more steps involved in making this chassis correct again other than stripping and repainting it. The entire chassis would require some serious oven time, straighten after its normalized and some more oven time. Big job!
    Dave
  24. Rock
    Rock Formula 3
    Nov 9, 2003
    1,652
    Toronto, Canada
    Rocco
    Robert, you have mail
  25. WILLIAM H
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    But you could reconstruct the chasis out of even stronger Chrome Moly w a serious roll cage for a lot less I imagine
