F40 running oil pressure? | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by Trax, Jul 31, 2017.
  1. Trax
    Trax Formula 3
    May 26, 2005
    1,383
    Douglas
    Has anyone got a table showing what oil pressure the car should be running under load when hot?
  2. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    I recorded a Tipo USA F40's oil pressure as follows:
    Cold startup - @ 80 lb/in
    Fully warmed on full boost - @ oil pressure peaked at about 110 lb/in
    Fully warmed idle - @ 40 lb/in
    Assuming the oil pressure gauge was working correctly, hope this helps.
  3. Trax
    Trax Formula 3
    May 26, 2005
    1,383
    Douglas
    The idle 40lb (2.75bar) is basically what I get
    but flat out in 3rd I'm hitting >9 bar (135lb) which is higher than I remember
