F40 smells of gas | FerrariChat
F40 smells of gas
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by zvdxb, Dec 4, 2016.
  1. zvdxb
    zvdxb Karting
    Aug 31, 2014
    201
    East/West
    ZV
    Hello ! Need some advice . I took the F40 out after 6 months ( too hot in Dubai from may to nov ) and drove it with a full gas tank. . When I got back home and parked it , I could smell gas. At first I figured it's because of the full tank etc... It's been 4 days and there is still the smell of gas in the garage and inside the car ( not unbearable but its there ) .Is there anything to be conccerend about ? If so what I should I look for ? Rgds
  2. ross
    ross Three Time F1 World Champ
    Mar 25, 2002
    37,993
    houston/geneva
    Ross
    look at some threads on this. many potential issues and solutions.
  3. Red Sled
    Red Sled Formula Junior
    Worth reading these:
    http://www.ferrarichat.com/forum/288gto-f40-f50-enzo-laferrari-sponsored-bradan/359214-f40-service-items.html
    http://www.ferrarichat.com/forum/288gto-f40-f50-enzo-laferrari-sponsored-bradan/253379-f40-fuel-bladders-2.html
    http://www.ferrarichat.com/forum/288gto-f40-f50-enzo-laferrari-sponsored-bradan/489436-f40-fuel-bags.html
    My own experience is that many shops will tell you that the smell is normal, and that the cars are venting. I have come across many Euro cars that have no petrol smell, so I didn't take that explanation as given, and eventually found the issue. Given the design of the car with fuel and hot parts in close proximity no to mention their age, it is worth getting is fixed.
    In summary, problems seem to be down to:
    1) Bad fuel tanks or leaky fuel lines (probably the most dangerous), but check if you have good quality tanks (OEM aero sekur, ATL) or aftermarket tanks of unknown provenance first.
    2) Leaky fuel pressure regulators (harder to spot - no visible leaks), but rusty.
    3) Bad fuel pressure vent valve - easy change
    4) Leaky injectors
    In my case, it was a a combination of 2) and 3) and while there was no immediate fire risk, the clogged fuel pressure vent meant that the bags in the tank would expand when hot/nearly empty and that was impinging on the surrounding parts.
    luigisayshello likes this.
  4. Arjun
    Arjun Formula Junior
    Feb 26, 2006
    330
    Don't forget the simple fixes first - F40s don't have charcoal venting systems of most modern cars have between the filler neck and the tanks themselves, so if you brim the tanks it will vent directly to the air. As others have mentioned, in a confined space this can become a fire hazard. The easy fix is to pull the car out of the garage, let it run for 20 min to get the fuel level down so that it is not venting to the air anymore, air out your garage and then park the car again. If it is still smelling after that, then investigate some of the other possible causes RedSled mentioned.
  5. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    I believe the cat cars have charcoal filters? as that was part of the overall early 90s updated euro emmision regs for all cars.
    Earlier cars more than likely have a floating ball type expansion valve, when gasses expand in the tank these lift the ball allowing the gas to vent to atmosphere until the pressure drops and the ball reseats and seals the system again
  6. zvdxb
    zvdxb Karting
    Aug 31, 2014
    201
    East/West
    ZV
    Thanks guys . I will have the car checked before I drive it again .
    Rgds
  7. 3604u
    3604u F1 Veteran
    BANNED Silver Subscribed
    Sep 27, 2004
    6,298
    london/singapore/JKT
    D
    Sorry out of topic , but any idea how many F40's are ther in Dubai.
    I love the car and hope to buy one in the next 15 mths.
    Am actively looking at the prices .
  8. zvdxb
    zvdxb Karting
    Aug 31, 2014
    201
    East/West
    ZV
    As per the official dealer , only about 6 ( including mine ) come in regularly for service so not many proportiately to number produced .
  9. TimF40
    TimF40 Formula 3
    Nov 3, 2003
    1,035
    Seattle/Bay Area/NYC
    Tim
    My US F40 had #4, leaky injectors. Dealer said the fuel smell was "normal" (after putting a lot of wasted time and cost trying to track it down). BS. Rifledriver fixed it right up.
    You might be able to locate the source of the fuel smell. On mine, after knowing what to hunt for, I could smell the fuel coming from one of the intakes. The injectors would drip and the smell would eventually waft up through the intake and be detectable in the closed garage.
    Tim
  10. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    That's a good working summary.
