F40 with black wheels... | FerrariChat
Discussion in 'Collectables, Literature, & Models' started by F40, Feb 21, 2004.
  1. F40
    F40 F1 Rookie
    Apr 16, 2003
    3,230
    AZ
    #1 F40, Feb 21, 2004
    I settled with F50 wheels, I like them... Need to find a way so they fit properly... going to have to make some hubs. What do you think?
  2. Scott85
    Scott85 Formula 3
    Dec 16, 2000
    1,240
    Dayton , OH
    The F50 wheels look good on the F40. Are the F50 wheels from a Hot Wheels too ?
  3. F40
    F40 F1 Rookie
    Apr 16, 2003
    3,230
    AZ
    Not sure, Tifosi12 would know since he kindly sent me the wheels... thanks again Andreas!
  4. karmavore
    karmavore Formula 3
    Dec 29, 2002
    1,641
    Hell
    Karmavore
  5. Gimme Fuel
    Gimme Fuel F1 Veteran
    Mar 15, 2003
    9,428
    In my 348
    Paul (Norway)
    Hey.
    Those black wheels looks great on the F40, is it difficult to remove the wheels
    on these model cars?
    How do you do it? just pull them right out without using too much force?
    or do you need to take the car apart first??
    Do you know where I can buy set with wheels?? (web site)
    Please let me know.
    Thanx a lot
    Paul
    wwwSuperCarCrash.com
  6. tifosi12
    tifosi12 Four Time F1 World Champ
    Oct 3, 2002
    49,446
    @ the wheel
    Andreas
    I think all wheels I have encountered have been put onto the axles so pulling them off would do the trick.
    However it seems as if each model uses a different "snap-on technique", so once you change wheels, you won't be able to put them back on. Which is why I normally give up and just glue the new ones on. Of course they won't turn anymore, but then again I got some models from professional builders and they did the same. So I don't feel too bad.
  7. F40
    F40 F1 Rookie
    Apr 16, 2003
    3,230
    AZ
    #7 F40, Feb 22, 2004
    I think I will just glue them on, once I put the brake rotors back on... I did have to modify the wheel hubs so they didn't stick out.
  8. Gimme Fuel
    Mar 15, 2003
    9,428
    In my 348
    Paul (Norway)
    OK, thanx for the info.
  9. Gimme Fuel
    Mar 15, 2003
    9,428
    In my 348
    Paul (Norway)
    Sorry, guys wrong pic.
    Hers the right one, just to make sure
    Paul
  10. tifosi12
    Oct 3, 2002
    49,446
    @ the wheel
    Andreas
    I have to do that in most cases as well. For the 348 Challenge conversion I actually let them stick out a bit. Looks kinda cool.
    Wrecked Ferrari: Yes, you got that right in the picture.
  11. Scott85
    Scott85 Formula 3
    Dec 16, 2000
    1,240
    Dayton , OH
    Wheels.
    When it comes to wheels , its best to stay with the same manufacturer (although sometimes you can't).
    Every Maisto wheel is basically the same and will interchange with all other Maisto hubs.
    Burago models have changed a bit. Some snapped right on the hubs, while others snapped onto the brake rotors.
    Hot Wheels uses straight axles in the back and usually screws the fronts into the hub. Although on some HW , they are just updated Buragos.
    UT glues them onto the brake discs(which are a PITA to take off).
  12. Chiaro_Slag
    Chiaro_Slag F1 Veteran
    Oct 31, 2003
    7,789
    CA
    Jerry
    #12 Chiaro_Slag, Feb 22, 2004
  13. F40
    F40 F1 Rookie
    Apr 16, 2003
    3,230
    AZ
    Jerry, Rick knows already :)... Not sure I told Tim though... Who has black wheels also.
